Question about Maytag Refrigerators
MAYTAG REFRIGERATOR MOD#MFI2568AES CONTROL PANEL LIGHTS ARE FLASHING ON LEFT DOOR. THE ICE CUBE SHUTE FLAP IS OPENING/CLOSING OBVIOUSLY NO WATER OR ICE IS THE PANEL SHORTING? IS THERE A RESET? REFRIGERATOR AND FREEZER ARE MAINTAINING TEMPS. I REMOVED PLUG FROM OUTLET...NO CHANGE WHEN POWER BACK ON
Posted by dobcodan on
5 Related Answers
the dr
joey shearer
  • 447 Answers
SOURCE: Maytag MFI2568AES Stainless Steel Bottom
perhaps there is ice holding it in because that tab is all that holds it.
Posted on Sep 29, 2007
Anonymous
SOURCE: Maytag Ice20 refrigerator
There's a very detailed guide explaining how to fix this yourself for about $5 in parts. Some basic experience with soldering is helpful.
My Maytag dealer did not offer to fix for free, so I resorted to doing it myself rather than spend $300-$400.
http://www.liny.net/MaytagIce2O.htm
Posted on Jan 30, 2008
Anonymous
  • 116 Answers
SOURCE: new just need manual
Try the following link:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=mfi2568&siteCd=MT_EN_US
Posted on Jul 28, 2008
57 varieties
Karl Wright
  • 1653 Answers
SOURCE: MAYTAG Model MSD2656KES: The refrigerator works
Sounds like the control module is u/s or the motor is u/s. Try switching off and on at the mains. If this does not cure it then you can try to unplug and plug back the ice motor, if you have access to it, if not call service engineer.
Posted on Aug 29, 2009
Testimonial: "The problem has just gone away. I think I overstuffed the freezer and something gets super cold or not ventilated properly."
SOURCE: cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Posted on Sep 12, 2009
Maytag Refrigerator Model Model #MFI2568AES
This a common problem with these units the high voltage in the main control board is the problem, the main control board in the back will need to be replaced. This runs about 250 dollars for the part. You can order it from this link.
http://www.repairclinic.com/Maytag-Refrigerator-Model-MFI2568AES-ID-657261-Parts?n=2
Nov 09, 2013 | Refrigerators
What does it mean when lights on control panel keep flashing and ice dispenser flap keeps opening and closing?
Ours started the same thing today. Called the 800- Maytag service number. They said it is a "known quality issue" with the controller and scheduled maintenace call. If gone unfixed, the controller will probably eventually fail and the frig will quit working all together. From what the lady said, this will be a free fix even though it's passed the warranty period.<!-- from fixya rte -->
Aug 11, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Mf12568aeb lights flashing and ice door flapping
You will have to call Maytag at 1-800-688-9900...Motherboard is bad. You can pull out the little plate at the bottom of the water/ice dispenser, then unscrew the two screw. Pull on the bottom and the panel should come out. Unplug the white connector on the left. This will stop the flapping of the ice dispenser flap.
Sep 23, 2009 | Maytag MFI2568AE Side by Side French Door...
The lights on the Ice and Water Dispenser flash
On left top side of door, remove cap and disconnect wire. This will turn off the control board on front of fridge and fridge will still run. Then follow this link - http://www.liny.net/MaytagIce2O.htm - click on frig picture at right and you will get step by step instructions with parts and tools you may need costing around $20.00 for a do it yourself fix.
Aug 19, 2009 | Maytag MFI2568AE Side by Side French Door...
Maytag MF12568AEB refrigerator
the high voltage control board is bad. located on rear of machine.
Feb 15, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerators Logo
505 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
