SOURCE: Ge Adora Front Loader
If you have not already done so, clean the filter behind the panel in the front bottom of the washer. Remove the three philips head screws to get the panel off. Unscrew the plastic filter on the right hand side (use a shallow cake pan to catch any water). Remove the filter and clean out the pens, pencils, change, lint, etc... and put back in. All should work well after this. Thanks, Greg
SOURCE: ge washer not draining or spinning
Washer will not drain or spin. Got the water out andf tried it . It would spin and seem to drain what little was left in the drum. When I added about 1" of water it would not drian or spin. Drum sets at an angle also.
SOURCE: torn gasket on a front load ge washer
Not too hard or technical. I followed John in Erie's instructions:
Replacing gasket is fairly simple - need 2 people. UNPLUG FIRST - 1. Remove the plastic cover on top of machine that is mounted to back of control panel. 2. remove dispenser - push down on tab at back and it will slide all the way out. 3. Remove lower front cover by removing 3 screws holding it on bottom. 4. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off. 5. Remove the 3 screws that hold the control panel on - note these are different type of screw so keep track of which screw goes where - one of the screws is next to dispenser opening. Once this is done you can reach in to machine and disengage locking tab on right side under "washer temp" - have someone hold this part aside if you do not want to disconnect the cables. 6. Remove spring loaded wire securing door seal to front cover. 7. Remove the the 4 screws holding the front cover on. This item is a bit heavy so be careful. Disconnect the three door latch wire harness and place this aside. 8. On the right side of the gasket you will find the clamp screw that holds the seal to the drum - loosen this screw almost all the way and remove this wire clamp. carefully remove the two tube connections and remove the gasket completely. Take note how these were installed before removing. Now you can carefully clean the gasket seats on the drown and door and replace the gasket and reverse the steps to put the machine together. While you have the covers off it would make sense to remove and clean the pump strainer mounted on the lower cross support - this can be messy with lots of water coming out so go slowly and have plenty of towels and a shallow pan to catch the water with. HOPE this helps.
I bought my part at Appliance Zone. From what I paid and how long it took to get to me, I should have just bought it locally for a little more and had it delivered a lot sooner. Replacement took an hour and a half.
SOURCE: my ge front loader washer will not drain
We had same problem. The pump was all clogged up with fabric debris, and a part of a metal bra liner. I removed the pump and cleaned it out. Now it seems to work fine, and went through a complete cycle. Ther pump was accessed from the front, and was not too hard to remove.
SOURCE: push start different sound water may start may not start pause
I would check to make sure the connectors to that door lock are all connected. If they are it's probably the lock/switch mechanism itself. Wow I just checked and they are about $120. The p/n is wh10x10006 You can google around for the best price. Good luck!
