Video Game Consoles & Games Logo
Posted on Nov 21, 2017
We have a Mad Catz RF adapter (universal for different types of gaming systems) that my son accidentally pulled out. The connector portion came apart and 2 of the wires were pulled off. I can solder them back on if I know what wire goes to what terminal. Any help with a scematic or diagram would be appreciated. Thank you.
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Dec 22, 2007
SOURCE: jbl wiring diagram
OK
See you CPU's backside  you will find  two different speaker input saket (in green ,yellow or pink) fix your speaker pins in their colors   and the speaker will work
Anonymous
  • Posted on Sep 16, 2008
SOURCE: wiring diagram
Had a three prong plug and now the new apt calls for a 4 prong plug...which I have but no diagram to show which color goes where.
Anonymous
  • 233 Answers
  • Posted on Jan 14, 2009
SOURCE: 1994 toyota 22re 4x4 pickup fuel injector wiring diagram
the color of the plastic plug does not matter... You will have two injector plugs with white/red and yellow wires - those two go to cyl#'s 1 and 3.
the other two plugs will have white and blur wires.. those two plugs go to injectors # 2 and 4.
Anonymous
  • Posted on Apr 03, 2009
SOURCE: PS2 Controller Wiring Diagram
heres the diagram
http://www.curiousinventor.com/guides/ps2
Anonymous
  • 6 Answers
  • Posted on Jul 11, 2009
SOURCE: Mad Catz MC2 Universal Wheel and Pedals Set. I've
http://www.madcatz.com/Default.asp?Page=43 for the manuals
Madcatz
You may need a different driver file. If the driver you are trying to use is 32 bit only, then you can not use it for 64 bit windows.
1helpful
2answers
I have just received a Madcatz MC2 wheel for the XBOX360 that I purchaced on ebay. However I cannot find out how to connect it as the lead from the wheel has a round plug and I can only assume that I need...
you have to go to amazon and type in "XBOX Controller to PC / MAC USB Cable Adapter" it only cost $4 plus shipping i had to do it to get my Mad Catz wheel to work with xbox 360. I paid $10 for mine rather then a hundered and works fine with all games.
Mad catz wheel
If you are using the ps2 slim for midnight club the controler won't fit perfectly you will have to wiggle the controler port around until it recognizes the controler
1helpful
How do I set up the mad catz wireless n gaming adapter?
you are wrong. your router provides the ip-adress. make sure the router has o mac-filtering and check if dhcp is activated in router (it is supposed to be).
Now make sure the ip-settings in the consoel is set to "automatic".
Should work.
2answers
Setup wireless adapter for xbox 360
Here is the manual for your product(assuming its the mad catz wireless N adapter): http://www.madcatz.com/UsersGuides/4707-MUG.pdf
You connect it to the computer first. However you need to find the setup disk. I looked around for you and couldn't find it, my apologies, but read that guide and you should have no problem setting up your gaming adapter
5helpful
2answers
5helpful
1helpful
3answers
Mad cats mc2 with pedals
The easiest way to do this is to go online and order a PS2 controller to PC adapter on amazon.com or some other site. I have a Madcatz MC2 and a Ps2 controller to PC adapter (a cheap one -_-") and it works okay (I'm having a lot of trouble with the pedals though).
Top Mad Catz Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Mad Catz Video Game Console and Game Expert? Answer questions, earn points and help others
