1997 Jeep Wrangler Logo
Posted on Nov 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 98 TJ 2.5, does anyone know if it has another numbers in the chassi? (except the three plates inside the car) tnanks
steve morris
Level 3:
  • Jeep Master 1,675 Answers
  • Posted on Nov 13, 2010
steve morris
Jeep Master
Level 3:
Answers
1675
Questions
0
Helped
653591
Points
5484
Hi no there is only the ones on the inside the layout should be like this for your one
1 Country of Origin 1 = United States 2 Make J = Jeep 3 Vehicle Type 4 = MPV 4 Gross Vehicle Weight Rating E = 3001-4000 lbs.
F = 4001-5000 lbs. 5 Vehicle Line Y = Wrangler 4×4 6 Series 1 = Sport
2 = SE
4 = Sahara 7 Body Style 9 = Open body 8 Engine P = 2.5L Unleaded Gasoline
S = 4.0L Unleaded Gasoline 9 Check Digit 0 through 9, or X 10 Model Year W = 1998 11 Assembly Plant P = Toledo #2 12-17 Vehicle Build Sequence Six Digit Number
incase the picture did not come out
2 Make J = Jeep
F = 4001-5000 lbs.
6 Series 1 = Sport
2 = SE
4 = Sahara
hope this helps.
Where can I find chassis number on Jeep Cherokee y.2003 and y.2005?Thank you
Chassis/VIN Plate
Cherokee VIN plate is located on the offside of the bulkhead on riveted metal plate adjacent to bonnet hinge . The body/build plate is on the nearside of the bulkhead and displays a VIN repeat.
A secondary position can be found in a sticker format on the bottom inside of the passenger door.
In later Jeep models the VIN data plate can be located on the passenger or rear passenger door pillar
Where is the chassis number located on a 1975 Bedford bus I've been told by the passengers front spring hanger or near the steering box . but I can't find it in those 2spots. Anyone help .
me ive got a 68 gmc and mine was on a brass plate inside the frame rail right by the engine mounts , maybe yours is something similar to this !???
Where can i find the engine & chassis number of audi Q7 2011 model?
The chassis number is usually the last 6 on the VIN, it is also located on a data plate inside the drivers door in most cases, on a data plate under the hood riveted on the body. The engine number is usually pressed into the block itself under the intake manifold. You can get this from the VIN as well as it is usually the series of numbers at the end with no letters in it. If your talking about the engine type code you can get that from the VIN as well but you have to take two 2 digit code from the VIN and reference that to get the actual type that was installed.
Nissan navara d22 chassi numbers
These numbers Engine and Chassis/VIN number should be written on the identification plate. This plate is located on the inside of the engine bay. It is attached up the rear of the engine bay, right hand side on the firewall. Just in front of the driver in a right hand drive vehicle, in front of the passenger on a l/h drive vehicle.
1helpful
1965 mercedes 190 fintail chassis No missing
The VIN is located on the top surface of the right front frame rail. this should be stamped in so it wouldn't fall off....hope this helps
2helpful
Freelander chassis number
under the passenger side-frame rail near the front tire
5helpful
Chassis number location other than on vin plate.2004 discovery es 2.5 diesel. thank you.
Location
The Vehicle Identification Number (VIN) plate is stamped on a plate attached to the bonnet locking platform. The VIN is also stamped in the following locations:
1) On a plate behind the LH lower corner of the windscreen.
2) On the chassis RH longitudinal behind the rear wheel.
1helpful
I need a fuse diagram for a 4 cylinder 98 jeep TJ. can anyone help??
AutoZone.com has a free manual database you can access by creating a free account and adding your car to your online garage. The manual has fuse diagrams.
Hope this helps,
matt
Sensors under chassis leg NS and where is the fuse for the fan
sorry unable to post picture, this site does not accept the format it is in.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
