The cam sensor is located at the front right front side of the cylinter head, while you are facing the engine.----------
The crank position sensor located below the pcv valve that is located on block not the valve cover, its below the exhaust manifold.
You will have to remove the catalytic converter to see the exact view of both the sensors.
The camshaft sensor is on the head. The crankshaft sensor is in the block, just below the exhaust manifold.
Thanks.Helpmech.
2002 Ford Escort ZX2 2.0L MFI DOHC 4cyl
Fig. Measure the CMP sensor voltage with the throttle assembly closed ...
Fig. ... then move the throttle assembly to vary the engine rpm and observe the CMP sensor voltage reading CRANKSHAFT Positilocation of cam and crank position sensors - zjlimited_65.jpg
Fig. Attach jumper wires from the CKP sensor connector to the
wiring harness, connect a voltmeter, start the engine and observe the
voltage reading
CAMSHAFT Sensor
SOURCE: crank position sensor location
you will need to remove the starter to gain acess to the ckp sensor. once you remove the starter look on the engine block and you will see the sensor. The only problem with doing this repair yourself is that you will not be able to preform the crankshaft position variation learn procedure with out a factory scan tool. The vehicle may crank an run, but the timing advance curves will be wrong so the vehicle will probably cut off every time you remove your foot from the gas pedal. Hope this info helps!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jonathan_3a3c556b4b17d1d2
SOURCE: Need to find Camshaft position sensor and crank se
CRANKSHAFT SENSOR - Under hood, center, front engine area, rear of crankshaft pulley, mounted in timing cover assembly.
CAMSHAFT SENSOR - Under hood, passenger side, upper engine area, mounted on engine in front of camshaft.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: cam position sensor
It is in the front top of the engine. It would be where the distributor use to be on this motor.
You have to partially drain the cooling system.
Remove the air cleaner outlet tube.
Disconnect the wiring harness from the coolant tube.
Remove the bolt from the coolant tube and postion it to the side out of the way.
Disconnet the electrical connector then remove the 2 bolts in top of it and remove it.
SOURCE: location of crank position sensor on 92 chevy corsica 3.1
You will have a no start or stalls after engine gets hot and then cools down restarts, the sensor is on the front of the engine mounted into the cam gear cover if it is not visiable get under the, (here is a picture) car and look.
