SOURCE: Kitchenaid KUDS01DL. The "Rinse
Turned off the breaker for the dishwasher overnight. It is working fine this morning.
SOURCE: KitchenAid dishwasher KUDS25SH - Can't operate because child lock
If holding the "Energy Saver/Dry" button does not solve the control board problem then most probably the control board would have failed and needs to be replaced .
To identify it we need technical expertise in handling the circuit boards and knowledge on usage of multimeter is must.
SOURCE: we just recieved our new kitchenaid heating
The control goes in the door...it is easy to get to.
Just take the screws out of the inside panel of the door, they are around the outside edge of the interior of the door. The panel will then lift off and the control will be near the top on the inside.
Make sure the power is turned off to the dishwasher and then one by one remove the wires from the old board and place them on the new board. then remove the old board and fasten in the new one. replace the panel and then give it a trial run.
Everything should be working just fine but some of the timing will be a bit different.
heatman101
Testimonial: "Thanks so much! "
