Question about Polaroid FLM-3232 Television
My Polaroid FLM-3232 TV Menu Window keeps popping up after the t.v. is on for awhile and wont go away. I keep closing the window but it continues to pop up. I had the Polaroid for about 4 years now. I had this issue for about 2 yrs but lived with it. I unplugged the tv for a month and the issue went away for a few months after. Can anybody help me resolve this issue?
Posted by jkholiday90 on
    Top Expert:
  • Polaroid Master
  • 76,376 Answers
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Posted on Sep 10, 2017
5 Related Answers
Anonymous
  • 298 Answers
SOURCE: flm 3232 polaroid
The power supply is only supplied with the control box. The control box is listed below.
Polaroid FLM3232 Control box with Power Supply
Posted on Jun 18, 2008
Anonymous
SOURCE: Polaroid LCD FLM-3232 Television
Go to http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen. Stiv0 posts the fix at the top, but go down about 10 posts or so and read mine (BlakeFromGa). I have some slight differences to my fix and a list of what you'll need.
Posted on Sep 29, 2008
Anonymous
  • 6 Answers
SOURCE: Sound but no picture.
It sounds like it is the picture tube. The same thing just happened to me. The back of my television started smoking and then there was no picture.
Posted on Jun 30, 2009
Anonymous
  • 30 Answers
SOURCE: Are the Polaroid FLM-3232 and the Element FLX-3202
not sure if there the same but the boards inside may be.
This sounds like the problem most LCD tv's get with swelled up capacitors in the power supply board. look for circular cylinder shaped parts rapped in plastic with writting on the sides, and metal tops, if the top is rounded over, not flat, it is bad. replace them.
Posted on Jul 22, 2009
Anonymous
SOURCE: If anyone is in need of Polaroid lcd tv parts contact me
usually capacitors are the problem on the TDA03211c power supply. 450v (volts) @ 10uf. change both. beside inverter filters.
Posted on Mar 31, 2010
My polaroid flm 3232 is 4 years old when I turn it on I get loud screeching and and popping sounds plus the picture is a color pattern. Can you help me?
Same thing happened. I unplugged it and everything for a couple of days then turned it on. Went to the menu and put reset to default. The V chip was then activated. If that happens to you too try 8202.
Dec 27, 2010 | Polaroid FLM-3232 Television
Tip
Polaroid FLM-3232 Service Manual Download
Download Polaroid FLM-3232 LCD HDTV Service Manual
Models: FLM-2632 / FLM-2632M / FLM-2634B / FLM-3232 / FLM-3232M
Models: FLM-323B / FLM-3234B / FLM-3732 / FLM-3732M / FLM-373B
Models: FLM-3734B / FLX-374
Have you misplaced your Polaroid FLM-3232 LCD HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3232 LCD HDTV Service Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Polaroid FLM-3232 Manual Download
on May 01, 2010 | Televison & Video
Tip
Download Polaroid FLM-3232 LCD HDTV Manual
Have you misplaced your Polaroid FLM-3232 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3232 LCD HDTV Users Guide?
Follow this link
I hope that helps.
_____________________________________________
Remote codes for the Polaroid FLM-323B
I may be able to help with your Universal remote and your Polaroid FLM-323B HDTV.
You can find some Polaroid HDTV Remote Codes here.
I hope that helps.
Oct 16, 2009 | Polaroid FLM-323B Television
Tip
I hope that helps.
on May 01, 2010 | Polaroid FLM-3232 Television
Tip
Follow this link
I hope that helps.
3232 polaroid tv,makes popping noise when i turn it on.
this sounds like the problem most LCD tv's get with swelled up capacitors in the power supply board. look for circular cylinder shaped parts rapped in plastic with writting on the sides, and metal tops, if the top is rounded over, not flat, it is bad. replace them.
Jun 25, 2009 | Polaroid FLM-3232 Television
Universal remote code for a Polaroid LCD TV
I may be able to help with your Universal remote and your Polaroid LCD HDTV.
I hope that helps.
Feb 26, 2009 | Polaroid FLM-3232 Television
Polaroid FLM-3232 Television Logo
157 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
