SOURCE: ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
SOURCE: SIDE BY SIDE Frig & freezer
hurlsdad.
Sounds like a noisy evaporator fan. Take the shelves out ot the freezer then take the panels on the back wall of the freezer off. The fan will be there. Then you will know for sure thats the source of the noise. When it is time to replace it...easy fix. (few screws) Here is an excellent source for the part..www.repairclinic.com. My favorite place for appliance parts.
hope this is helpful,
handiman518
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
SOURCE: GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
SOURCE: frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
