Braun Flex Integral 6520 Electric Shaver Logo
Question about Braun Flex Integral 6520 Electric Shaver
How I change the battery and what is the cost of a battery.
Posted by luisfran on
shaveroutlet.com
  • Braun Master
  • 1,649 Answers
If the shaver still works but just will not hold a charge as long as it should, you can fix this by replacing the batteries. If the shaver is dead and will not run and the green charging light no longer illuminates when you plug it in, you will need to change the whole circuit board.
You will find the batteries and the circuit board with batteries at shaveroutlet.com. You can order which you require by viewing the links below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
http://shaveroutlet.com/shaver-replacement-parts/braun-printed-circuit-board-with-batteries-p-106.html
To open the shaver, you will need to pry out the two round plastic screw covers on the bottom then remove the screws underneath. You can then remove the outer case by sliding it down and off of the shaver bode. Then remover the black plastic cover inside to access the circuit board and batteris.
If replacing the entire circuit board, you will simply lift it out and replace. If just replacing the batteries, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Posted on Nov 07, 2010
2000 Lincoln LS had dead battery. Put in new one now the horn blares, radio blasts, lights go down. Pressed button on FOB to reset. turned car off and on; didn't work. Unhooked battery and left it.
How much is this going to cost? ????? Without testing to find out what the problem is , no idea . Your best bet , take it to a qualified repair shop an have it diagnosed .
On me Honda Civic 2006 hybrid 12 v battery do not charging.
The alternator is what keeps your battery fully charged. How old is the battery? If is within the time it’s supposed to last and it is defective, then take it to the place you purchased it and they should prorate the cost of a new one. Also check to see that your alternator is working, that it is charging the battery as you run the engine. If it has stopped working then you need to replace it. The cost could be from 75-175 dollars depending on the quality and warranty you choose. I recently changed mine on my GMC truck, cost $98 and took only 30 minutes to change out.
I need replacement batteries, any suggestions?
You should specify make an model of your shaver and if you have tha user's manual.look thare what it says about batteries.
Generally, my experience with rechrgable batteries for shavers is that they are not "user servicable" and you must take them to repair to get the batteries change - if they ara available, so when you calculate cost of new battery and service, might cost almost same as a new shaver.
Battery not charging
you should change the battery which cost around 35% of the cost of ups i have same problem
2helpful
3answers
I am having a battery back up problem with my samsung sgh f-400, the battery lasts for only for 2 hours after charging it for full. I have replaced 3 to 4 batteries, but there is no result, And the...
the problem isn't the battery.
the problem is from "supply center" of your phone.
i recommend you to completely change your phone.
because cost of repairing the phone in a gurantee center (if the warranty has expired)
is higher than cost of buying a new one.
How do I change battery.
mcdevito75 here, You:d need a couple of watch tools to change the battery, the cost of these tools and the cost of a watch repair shop to change the battery for you are similar. Look for a small watch repair shop in your area to save on the cost of replaceing the battery.
2answers
Battery keeps dying on me.
you dont reprogram!!
just replace battery!!!
CHANGE YOUR MECHANCI!!!!
PSP Charging problem
TEST : Take battery out. Plug in to wall. Wait 30+ secs with psp on. if the power turns off, then its the adapter which is broken, which costs about 5$
OTHERWISE:
Your battery needs to be changed. Standard flavor costs bout 8$, extra long lasting spicy flavor costs 16$. (lol, chips)
Seriousley though, after some time, wear, and in some cases, temp. changes, the battery can become so weak, that it will only hold about a 5 second charge. Once you get less than 1 hour play time W/O charger, need to get a new battery.
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
David Shaub
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
