Overhead Garage door lights will not go out like they are suppose to. I thought maybe the timer was not functioning. This is a Sears LiftMaster model 139.53515SR. I would appreciate any advice how to fix this.
Hello. If the light stays on all the time check these: A.The light time delay on the opener will keep the light on for approximately 4-1/2 minutes after the system has be activated, then will turn the light off automatically.
B.If the opener has a worklight switch (which is supplied only with a four-function wall console), slide the switch to "OFF" position.
C.If the opener has apedestrianswitch (which is supplied only with a four-function wall console), the light will stay on for 4-1/2 minutes after the pedestrian door has been opened.
This is not too uncommon. What tripped the breaker in your house also got to one of the relays on the logic board of your opener. The only cure I know of is a new logic board.
I have Sears Craftsman model 139.58778 and the remote is suddenly not working for no apparent reason. The transmitter in the garage works fine but the portable unit for the car does not. The red light goes on and the toggle switches are correctly set and match the overhead unit setting. Any ideas what is wrong? I purchased a new remote and it did not work either after being correctly set, Thank you!
