SOURCE: I can't get all the channels using the remote
I enter the menu button, channel, add, and it begin to add the channels for cable.
SOURCE: Dvd will not play movies
If you are getting a blue screen when you try to play the dvd, try this. Hit the input button on the tv remote. A list of items will come up. Hit the input button again and again until you reach the item on the list that says AV. Your dvd should then play just fine. One last thing. Once you get the dvd to play the parental code setting may come up. It says something like the parental code has been set. Select yes. It will ask you for a password. The password is 1369. You should have no problems.
Good Luck
SOURCE: Connecting dvd player to zenith sy2551s system and doesn't work
Yes, You need to be on AUX ,you can get to that setting by pressing channel 01 then press the channels down button instead of going to channel zero it will start to cycle through your AUX's inputs on the back of the tv.Also, another way to do this is on the original remote there will be a SOURCE button or INPUT button that can also cycle your TV through the aux inputs.REMEMBER.Make sure your DVD player is turned on and hooked up or else the AUX screen will be black.Rate me when you fix it!GOOD LUCK
SOURCE: can't get TV onto the AUX channel
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
SOURCE: Is there an input select?
I can view channels but cannot view a DVD from the TV/DVD Disney Princess Combo. Only see static on the screen with no sound. I wonder if I need to change the input select to view a movie but cannot find a button on the TV or remote control. I have a 6 button remote which I am sure operates the DVD and another remote with 39 buttons I thought would operate the player as well as the TV. However, so far only the player functions from it. The buttons only have small pictures without words which sometimes leaves some question about purpose. This is a second hand unit. I do not have a manual. It did play movies at first. I think the trouble may have started when I programed cable channels. Any help will be greatly appreciated
