SOURCE: Fuji FinePix S9000 battery change clears date/time.
Hi
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
F
SOURCE: is there a repair for command dial on a fuji s9500
Yes. contact Fuji and it cost about £14.00, its a doddle to fit.
When you recieve it you'll work out how to remove the broken part because you'll understand how it locates, basically a small Pozi screwdriver and a sharp knife to lever the top off.
SOURCE: Fuji E550 loses date and time every time i change batteries
Theres a small back-up battery located on the main
power board. It's not a DIY project to replace this battery.
Testimonial: "thank you...appreciate the help. :)"
