There is a clear plastic piece mounted on the waste toner container. The printer sends a light through this clear plastic to detect whether the container is full. You will need to ensure you are able to see through the clear plastic to reuse the waste toner container.
Thank you so much!!! You are a life saver.
Thank you this worked for me as well. Scr3w you Canon and Ginko the guy below this post, free is better than paid.
Ginko guy forgot to tell you that waste toner is a radioactive toxic hazzard after being in contact with the drum and now you are going to die of cancer
Hi Scott.
As I am a qualified technician I need to advise that the toner must be disposed by manufacturer.
Here the link to replacement part.
About the reset, here the service manual.
Download the manual and follow the instructions in section 8. Menu to clear the waste toner counter is Service Mode>COPIER>COUNTER>DRBL-1 .
To start Service mode:
Startup [SERVICE MODE] (After pressing [USER MODE] button of MEAP device, press [2]
button and [8] button at the same time on control panel. Then, by pressing [USER MODE]
button again, [SERVICE MODE] screen is displayed).
To see position of waste ink bottle, check section 2-72 in manual.
Manual is over 1000 pages, you will need to download it.
Regards.
Ginko.
am not seeing this clear plastic
It is attached with a screw on the side opposite the gears
