If the drive cant locate go to device manager click on hardware changes ....or locate CD drive in device manager unable it if it is in disable mode.
Hello Jean1042, I can give you a video that will help you solve this problem and I will do it, but in my particular opinion you can achieve the same task with other applications that actually work better and have more options, I also leave a link to the that I use (does not have to change, it's just an opinion)
2) Official download of VLC media player the best Open Source player VideoLAN
3) http://www.burnaware.com/download.html
SOURCE: T2 AE1
Make sure the cmos setup is set to try booting from the CDROM. There are various methods to access cmos setup...but usually you need to press either the Delete key, or F10 or F12 right after turning on the power.
If it won't boot from the CDROM, the problem is is more likely to be in the power supply or motherboard than the hard drive.
SOURCE: Windows unable to detect modem.
hi,
Update the windows xp or the operating system. else go to my computer icon , right click it and then go to properties and go to hard ware tab and press device manager and right click the modem tab and press update driver.
