Question about Euro-Pro Shark GI490 Iron
No power from cord. I want to replace the cord.
Posted by conscioustho on
Amado Petallana
  • 320 Answers
In replacing the cord, you have to remove the screw that holds the back cover and unscrew the damaged cord from the heater terminal. Insert the new cord on the rubber insulator and screw it to the heater terminal.
Posted on Nov 04, 2010
Akoyaw Rudder
    New Friend:
Gm my name is akoyaw rudder. my question is what type of tool is needed to remove the screws from the back of my G1435N product thank u
Posted on May 05, 2013
  • TMasud May 18, 2013
    Have you found the tool to remove screws from back cover? I have the same problem, don't know where to find that kind of screw driver
How to replace power cord on a sunbeam 4214 iron
www.laundry.manualsonline.com has free manual
Jun 09, 2014 | Sunbeam Irons
I am having problems with my cord when I move the iron the iron shuts off. How do I fix this problem? DM880.
just replaced the power cord, you can buy wire and plug then assembled it to the iron and replaced the old power cord which may cause of shut off.
Nov 28, 2012 | Irons
When I plugged iron in sparks came out at wall and iron where the cord connects.
If you've had this iron for a while it sounds like the cord may be frayed.
switch it off at the wall and unplug it, check the cord for wear, if the insulation is frayed, torn or broken and there are black burn marks on the cord where you saw sparks then the cord needs to be replaced.
DONT plug the iron back in until the cord is replaced.
Otherwise If there are no breaks or black burn marks on the cord, then your power point may be faulty and needs to be replaced!
I hope this was helpful
MobileJB
Jul 13, 2011 | Oreck Cordless Speed JP8100CA Iron
Rowenta model dm 860 loose power cord
Most high end appliances (like Rowenta Irons) are made so repairs like that can be done. I haven't played with that model, but I did replace a cord on my Norelco. The torx screwdrivers you are looking for can be purchased, and are often found at either specialty electronic stores (not the average Radio Shack), automotive stores and quite readily online. They are also known as Torx Security bits or Torx Safety bits. Most appliances are made with those screws to prevent the average person from having a go at trying to fix it, but, if you feel comfortable enough with the electronics (even just to look for a loose connection), the bits are available and usually at a fairly decent price.
Jul 22, 2009 | Rowenta Irons
Cord short ccircuit
The back comes straight off. All you need to do is take a small screwdriver and pry against the bottom metal piece, then it should start to come off. Make sure you take it off carefully so as not to break anything. Pry evenly all around the plastic end cap until it comes off.
After that, you can replace the cord. It's connected via two crimp caps. Easy to replace. Just make SURE you purchase a cord rated for an iron.. DO NOT clip the plug end from an extension cord or similar and use it. The iron uses 16 gauge HEATER CORD. Easy to find, but you could melt your power cord and possibly cause a fire if you don't replace it with the correct type.
Mar 13, 2009 | Black & Decker D2020 Iron
My iron needs a new cord
purchase it from==
http://www.powercord-manufacturers.com/
thank you for using FixYa
Nov 14, 2008 | Black & Decker Irons
Euro-Pro Shark GI490 Iron Logo
1,066 people viewed this question
Top Euro-Pro Irons Experts
Sheldon Dedek
Andrew Taylor
Andrew Taylor
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
