Canon LaserBase MF5630 All-In-One Printer Logo
Posted on Nov 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to install my canon lasterbase mf5630 all-in-one printer to my laptop which has windows 7 installed. but my laptop doesn't recognise it. tried to download the driver from canon.co.uk/support but all the drivers are 32 can't get 64bit. please help.
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 12, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2468117
Points
19564
1helpful
My Lexmark e332n shows error code 43 ,what does it mean?
G'Day Mate,
Are you running the Lexmark driver for Windows 7 64 bit.
Try down loading the driver and installing it on your p.c.
Suspect USB driver for printer is missing - Windows can't detect it as it doesn't recognise it. By installing the Lexmark driver it updates windows to recognise the lexmark printer usb interface.
you will find driver here
http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_E332N&segment=SUPPORT&userlocale=EN_US&frompage=null#1
Canon laserbase mf5630 windows 7 64 bit vitual pc
You can find the solution here: http://www.fixya.com/support/t11518807-looking_driver_mf5630_canon_win_64
2helpful
3answers
Looking for driver MF5630 canon Win_64
I have spent hours to find a solution... there is no driver. But there are definitely 2 solutions:
1. MF5630 - using ONLY printer in Win 7 x64:
You have to use the drivers for MF5700 Series - http://driverscollection.com/?file_cid=4213082682609f383f81540957d
- http://www.techulator.com/resources/4156-How-add-Printer-manually-your-Windows.aspx
1. First, Click on the Start button in your screen, further click on Control Panel button and then double click on Devices and Printers button.
2. Then click on Add a Printer button in the menu.
3. Further select the Add a local printer button from the available menu.
4. Then choose an existing LPT port and click Next button .
5. Further select the correct driver from the driver list menu for your printer. Suppose if the requisite driver is not available then click on the Windows Update button. After the Windows 7 Update installation finishes in your computer, once again search for the appropriate driver for your printer.
2. FINAL SOLUTION - for printer and scanner - if you have proper PC configuration:)
Win7 has a possibility: http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
you can install the WIN XP environment where you can easily install driver for Canon MF 5630 (or any other by Win7 x64 not supported printer/scanner) and additional software.
BUT YOU NEED to run: Windows 7 Professional, Enterprise, or Ultimate editions. Windows XP Mode is not supported on Windows 8.
Your BIOS must support Virtual Machine.
Is MP370 - Windows 7 compatable ? I cannot install
Yes, it is Windows 7 compatible. You can find the drivers for the printer at the link below. Just download and install the driver for your computer and the printer should be installed. If it doesn't install that way open up control panel, go to devices and printers, go to add a printer, choose local printer, use the default port and click next, choose have disk and select the drivers that you just installed, then just click next through the rest of the wizard. Just make sure you can print a test page.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/multipass_series/multipass_mp370#DriversAndSoftware
Osx driver not found mf5630
my pc currently using window7.....but my mf5630 cannot support window7.....how i can soft this problems?
3answers
I no longer have my installation CD for my cannon laser base MF5630
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
You can download the required installation drivers from manufacturer's site by clicking this www.cannon.com
Select and download the drivers according to the operating system of you computer (Win XP/Vista,others...)
2answers
Can't install my printer
The best site for downloading a software for your printer is the website of your printer brand name. Probably, www.canon.com
Don't forget to rate me..:-) Thanks..
3helpful
2answers
I have lost the installation cd for my printer how can i install it now
you can download a copy of driver for your printer from here
Click here to Download
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
old marine
old marine
ZJ Limited
ZJ Limited
