2006 BMW Z4 Roadster Logo
Posted on Nov 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brake pad wear indicator light does not go off at the dash after changing rotors brake pads and the sensor in the front wheels all pads and rotors and the sensor is ok at rear. the vehicle has only 30000 KM 2004 BMW Z 4 Roadster with 2.5 litre engine
ZJ Limited
Level 3:
  • BMW Master 17,989 Answers
  • Posted on Nov 04, 2010
ZJ Limited
BMW Master
Level 3:
Answers
17989
Questions
0
Helped
14457526
Points
60858
Did you change the sensor? if you did, do a battery reset (disconnect for 10 to 20 min.).
Obviously the wear sensor has made contact with the rotor and is already damaged. You're not even suppose to resuse the wear pad sensor if its worn or damaged anyways.The way how the sensor works is that it must make contact to the rotor to complete the wear pad light indicator circuit. There is no mentioning that he replaced the the wear pad sensor with a new one.
But if one did replaced the wear pad sensor and the wear pad indicator is lit up, the way to reset it is to leave the key on in ignition switch #2 or #1 for about 30sec. turn it off and its reset.
Its possible that you forgot to replace the brake light sensors. They are about 15 bucks, and have to be replaced in order for that light to turn off. You can either get them from the dealer where they'll likely charge you 3 times as much, or you can go to http://www.turnermotorsport.com and get them there.
You have to reset the light by leaving the ignition switch on position #2 for about 30 sec. turn off the ignition and start the engine up and see if it goes out. I recommend buying a new wear pad sensor as well because now light will lit up when you're way below spec (less than 3mm)
Also, you could try with this procedure for one E39: Turning off the Check Brake Linings warning on the Instrument Cluster...
- so you've just changed the brake pads on your E39, along with the wear sensors. The old sensor(s) needed replacement cause you waited a bit too long before changing the pads, and wore through the sensor(s), turning on the BRAKE light on the dash. But wait, the light is still on? But there's a new sensor installed... what gives?!
- there is a procedure required in order to turn off the light/warning. With the ignition off, step on and hold the brake pedal. Now, while holding the brake pedal down, turn on the ignition switch to position 2 (just before cranking). Hold the brake pedal until the BRAKE light is off. Tada, the warning is gone and reset.
NOTE: This procedure worked on a 2001 E46 325i. It took about 15-20 seconds, but it cleared out w/o having to unhook the battery.
Other details find in the Owners Manual 2006-BMW-Z4m-Roadster-Owner-Manual
Keep us updated.
3helpful
A light in the dashboard turns on today and I have no idea what is the symbol for? is like a circle with 3 rectangles in line on each side this is a BMW 318i, 1996
This is the brake wear indicator. When the brake pads get too thin, this sensor, which is mounted in the brake pad backing on the front left wheel and the rear right wheel, touches the rotor and wears through, grounding out the contacts and illuminating the light.
Once the light is lit, you will need to buy a new sensor as well as new brake pads. The sensor is not expensive.
First step is to examine the brake pads and determine if you need front pads or rear pads or both. Don't be surprised if you need new rotors as well as pads. Check for a significant lip at the outer edge of the rotor. If the pads have worn in the sides of the rotor more than about 1/16", you are due for rotors.
You cannot go wrong with BMW branded pads. They are safe and work great, but they are really dirty. If you want to try other brands, read the reviews. Some squeak and some fade.
I use Mexican made Brembo rotors. They work well but they rust quickly, so the brakes squeak a bit the first time you press them after washing the car or driving in the rain. More expensive rotors or BMW branded rotors don't rust so much, but they cost a lot more and don't necessarily last any longer.
After replacing the pads, turn the key to the On position and leave it on for about 90 seconds before starting the car to reset the brake pad warning light.
2helpful
2answers
2002 Pontiac Grand Prix making noise on l-f wheel. Sounded like brake indicator so I took apart to check and there is a tab about 3-4 inches long rubbing on brake rotor. Is this an indicator for some thing...
  • This is called a sensor. When the pads ware down to the point they need to be changed those sensors will begin to scrape on the rotor. If the pads are not changed real soon they will ruin the rotors too. I recommend a replacement of the pads and an inspection of the rotors real real soon.
  • Thank you for using FixYa
Regards, Tony
2answers
What would be the causes for brake lining study light to come on in a bmw x5 2005.
Study light? Do you mean warning light?
There are sensors clipped into the brake pads on the front left and rear right wheels. When the brake pads get very thin, those sensors rub on the brake rotors, and the light illuminates in the dash indicating that it is time to replace the brake pads.
The light can also illuminate if something damages the wire to the sensor. I usually replace my pads before they get down to the sensors, so I re-use my old sensors. Although the wires are fairly well secured to the suspension, after a few years, the wires can get chaffed from the wind blowing them around, and the damaged wire can turn on the warning light.
Feb 27, 2011 • 2005 BMW X5
2answers
How to change brake pad and check rotors
Brake Pads Removal & Installation Front for_car_toy_cam_02-04_sst_frt_dsc_asm.gif
To Remove:
  1. Drain brake fluid to ½ full level in reservoir.
  3. Remove the front brake caliper assembly.
  4. Remove the 2 anti-squeal shims from each of the 2 brake pads.
  5. Remove the wear indicator from each of the 2 brake pads.
To Install:
NOTE: When replacing worn pads, the anti-squeal shims must be replaced together with the pads.
  1. Using a large C clamp or equivalent press piston into the caliper.
  2. Apply disc brake grease to the inside of each anti-squeal shim.
  3. Install the anti-squeal shims on each pad.
  4. Install the pad wear indicator clip to the pads.
  5. Install the pads with the pad wear indicator plate facing upward.
  6. Install the brake caliper with the 2 mounting bolts. Torque the bolts 25 ft-lb (34 Nm).
  7. Install the front wheels.
  8. Fill the master cylinder with new clean brake fluid.
  9. Pump the brake pedal several times to seat the brake pads.
To Remove:
  1. Drain the brake fluid to ½ full level in reservoir.
  2. Remove the rear wheels.
  3. Remove the caliper slide pins.
  4. Remove the caliper slide pin bushings (TMMK made) (Kentucky).
  5. Remove the rear brake calipers.
  6. Remove the 2 brake pads with the anti-squeal shims.
  7. Remove the anti-squeal shims and pad wear indicators from brake pads.
To Install:
  1. Using a large C clamp or equivalent press the piston into the caliper.
  2. Coat both sides of the outer anti-squeal shim with pad grease.
  3. Install anti-squeal shims to each pad.
  4. Install wear indicators on the 2 brake pads.
  5. Install the caliper slide pin bushings (TMMK made) (Kentucky).
  6. Install the rear brake caliper with the slide pins. Torque the slide pins as follows:
    • TMC made (Japan): Torque the caliper slide pin 25 ft-lb (34.3 Nm)
    • TMMK made (Kentucky): Torque the caliper slide pin 34 ft-lb (47 Nm)
  7. Fill the master cylinder with new clean brake fluid.
  8. Pump the brake pedal several times to seat the brake pads.
  9. Install the rear wheels.
prev.gif next.gif Brake Rotor Removal & Installation Front To Remove:
  1. Remove the front wheels.
  2. Remove the front brake caliper assembly.
  3. Remove the front brake pads.
  4. Remove the 2 bolts and caliper mounting bracket.
  5. Place match marks on the disc and axle hub.
  6. Remove the front wheel disc.
To Install:
  1. Align the match marks and install the front disc.
  2. Install the brake caliper mounting bracket. Torque the bolts 79 ft-lb (107 Nm).
  3. Install the brake caliper. Torque the bolts 25 ft-lb (34 Nm).
  4. Install new gaskets and connect the brake hose to the caliper with the banjo fitting bolt. Torque the fitting bolt 22 ft-lb (29.4 Nm).
  5. Fill the reservoir with brake fluid.
  6. Bleed the brake system.
  7. Install the front wheel.
Rear To Remove:
  1. Remove the rear wheels.
  2. Remove the brake caliper assembly.
  3. Remove the brake pads.
  4. Remove the 2 bolts and the caliper mounting bracket.
  6. Remove the rear disc.
To Install:
  1. Align the match marks and install the rear disc.
  2. Install the rear brake caliper mounting bracket. Torque the bracket bolts as follows:
    • TMC made (Japan): Torque the bracket bolt 46 ft-lb (61.8 Nm)
    • TMMK made (Kentucky): Torque the bracket bolt 34 ft-lb (47 Nm)
  3. Install the rear brake caliper with the slide pins. Torque the slide pins as follows:
    • TMMK made (Kentucky): Torque the caliper slide pin 32 ft-lb (43 Nm)
  7. Install the rear wheel
Squealing sound - front driver's side brakes
This sounds like a wear indicator( a metal tab on the brake pad) is doing its job, warning you that the brake pads need replacement soon. you can bend the wear indicators away from the rotor so they won't make contact. This will stop the annoying noise. Replace the pads and check the brakes soon. Brake pads should always be changed on both wheels at thge same time, so change the other front pads also.
2answers
Brake pad warning light on golf gti 1.8t 1999 t reg
Brake wear indicator and low brake fluid warning indication are two different circuits.
They are not related.
Easy route to check brake pads is the measure the gab between the rotor and the metal portion of the brake pad.
If it's low then replace it.
The right way is to pull the tires and measure the thickness of the remaining brake pad.
Most shop give free brake inspection with oil change,
Check it out before the pad cuts into the rotor and it will DOUBLE the cost of your brake job.
1helpful
Consistent Wheel Squeaking - Right Front Wheel
This may be a worn down front brake shoe or pad, some after market pads come with a wear indicator.
This wear indicator rubs the rotor when the pad is in need of changing.
5helpful
2answers
I replaced the front pads on a VW JETTA 2.5 and the check pads light is on. How can I reset the check pads light?
As the brake pads wear, the brake pad wear sensor contained in the brake pad contacts the brake rotor. This causes the sensor to fail. When a pad wear sensor fails it opens the ground circuit of the pad wear warning light system causing the pad wear warning light to illuminate. Perform normal brake service to correct this condition and be sure to replace the brake pads with pads containing wear sensors. Once the brake pads and wear sensors are replaced, reset the brake pad warning system by turning the ignition switch to the "on" position. As long as continuity to ground exists through all the brake pad wear sensors the system should reset and the pad warning light in the dash will go out. If the pad warning light does not go out, a check of the pad warning circuit for an open circuit condition or poor ground must be performed.
8helpful
3answers
Brake Pad Sensor
i have replaced both front/ rear pads, and no matter what the dash light will not go off. I have disconnected both front/rear sensors, and light is still on , any suggestions?
7helpful
4answers
Brake Pad Sensor
On my bmw 325i front pads changed,indicator on dash still on,help!!
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
