Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
Insert memory card and says card not read, format disk. Camera menu wont allow formatting.
Posted by fernv322 on
Anonymous
    Genius:
  • 1,177 Answers
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Posted on Nov 04, 2010
Hi I have 8gb Transcent Micro Sd Card that is encounted a problem when i m downloading using 5130. After that its not opening Its Says that not Formatted. when i insert in to my pc only showed my card...
If there are hidden partitions on the memory card, Windows 7 will not allow you to change the partition. So to format use a PC with windows XP or older. You also could format this card in most camera's. For that place the card in a SD adapter and put it in your camera. Let the camera do the format.
When you put the card back in the phone, make sure you first format the card with the phone software. Just to be sure the phone can read and write the card.
Camera wont read the disk
Coolpix cameras do not have a disk; they use an SC memory card. When you put a new SC card in the camera, you must format it before you use it. Go into your camera's Menu. Under Setup, you will find "Format memory card". Once your SC card is formatted it should work.
Hi how do i formatt my camera card
From page 63 in the manual.
Format
Internal memory format : Remove the SD memory card to format the internal memory.
SD memory card format : Insert the SD memory card to format the SD memory card.
All the files in the memory are deleted by the [FORMAT] function.
Before formatting the memory, it is advisable to copy important data onto other media as back-up
e.g. floppy disks, hard disks, CD etc.
1. Turn the camera power on.
2. Select the PLAY mode by rotating the mode dial.
3. Do not turn the LCD monitor off.
4. Press the MENU button to display the menu on the LCD
monitor.
5. Press the UP( )/ DOWN( ) button and select [DELETE].
6. Press the SET( ) button and the sub menu will display.
7. Select [FORMAT] by pressing the UP( )/DOWN( ) button
and press the SET( ) button
8. Select [NO] or [YES] and press the SET( ) button.
[Selecting NO] : The image will be displayed on the
LCD monitor.
[Selecting YES] : A [PLEASE WAIT!] message is
displayed and all of images are
deleted.
Link to manual:
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=2702&prd_mdl_cd=EC-D201ZSBA/E1&prd_mdl_name=DIGIMAX%20201&srchword=digimax%20201
2answers
Hi, Our daughter has a Samsung ES30 12.2 megapixel camera. I just put a new sd card in and it says Card Error, When you click on OK, it tells you to 1. Turn the camera off and on again, 2. remove and...
You need to format the card.
Insert the memory card into the system and this will be displayed as the mass storage device in my computer. Right click over the removable disk and then click format. It will format the memory card.
Then insert the memory card into the camera. Now the camera will not show the error message.
Hope this helps.
Shane
Apr 04, 2011 • Cameras
How do I format the memory card?
You can format your memory card in one of two ways 1. the camera menus usually have a functionality to format memory cards. Explore the camera menu a bit and you will find it. 2.You can insert the memory card in the card reader of your laptop or USB card readers sold separately. When you plug in the card in your laptop it will show up as a removable disk in My Computer right click on the removable disk icon(make sure you are selecting the right removable disk icon) and select format.
Mar 02, 2011 • Cameras
I have a brand new PENTAX E70L camera, with SD memory card. i took a few photos on it and then turned it off. Now when i turn the camera on it reads -card requires formatting.I press continue , to format...
Make sure you don't have any pics on the internal memory. To be sure, with no card in the camera, go into the menu and find "format" and follow the on-screen instructions. Then, insert the card and go into the menu and do the format thing again to erase the card and optimize it. Use the menu and not the format option the camera has been giving you.
My camera wont read the memory card.. just internal memory. it wont let me take pictures either. how do i fix it?
With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card.
My camera doesn`t read memory card.I tried with 2
On most cameras, once you start to use the internal memory, the camera doesn't want to read a memory card. You need to go into the menu and "reset" the camera. Then, with no card in the camera, go into the menu and "format" the internal memory. Then, insert the card and "format" it. This will erase it so download any pics first.
1helpful
Memory Full/Format disk
it needs to format it to allow it to read by the camera...a sort of hand shake..so format it and go shooting
Sony 512mb Memory card
You can insert the memory card to the card reader and then insert the card reader to the PC. Access the drive where the memory card created and then right click it and then format.
You can format also using the menu of the camera. refer to user manual in formatting camera storage disk.(memory card)
may this help:
melnavz
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Ekse
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
