Hello the driver can you download here:
http://support.asus.com/Download.aspx?SLanguage=en&m=A7N8X-E%20Deluxe&p=1&s=10
Select your windows
Select your driver and hit global for download
Unzip the file before installation.
Good luck
SOURCE: asus a7n8x-la
Hi - You can download the manual from the link underlined in blue below:
a7n8x-la
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
SOURCE: Sata hard disk drive on asus p4v8x-x motherboard
Okay. If your board has SATA connection slots it most definitely is SATA compatible. Check on your motherboard how many SATA slots you have, make sure that your HDD is connected to on the Mboard with any other drive in a numerical order (on the Mboard right next to the SATA slot it should read SATA 1 or SATA 2 ........). If that does not work plug is you HDD drive loosely so that when you switch on your computer you can listen to the HDD. should it emit a humming sound, meaning its powering up the problem could lie with your SATA slot or SATA Data Cable, try a different DATA cable if this does not work try blowing air into the SATA slot on the Mboard, If no luck then maybe the slot is burnt out or malfuntioning. Should you not hear a humming sound coming from your HDD then its either faulty or the there is no power going to it. try to alternate between the cable of your power supply. Try these and Please let me know how you go.
Regards
SOURCE: A7N8X Support CD
A lot of files for your motherboard here:
http://members.driverguide.com/index.php?action=dosearch&qm0=a7n8x&qa5=1&qa6=122&dp=3&sm=h&jmd=and&fzz=d
please 'fixya' if it is what you are looking for!
SOURCE: Asus M2N motherboard ATA problem
Hi, Go into the POST and set it back to the default setting. Reboot and see if the cd/dvd rom drive. If it still does not recognize the drive, then try using a different IDE cable. Question, did the MB work fine and all of a sudden it does not regonize the drive? By the way, I have the same MB. So far I have not encounter any problems with it. Thanks, Mike
