Question about Xact Communication X32X-2 2-Way Radio
I need an Owners Manual for these 2-way FRS/GMRS, Wristwatch, Walkie-Talkie, radio's. The model # is... x32x-2. They have a Range of 1.5 miles supposedly. I received these Walkie-Talkies from Marlboro several years ago, when they were running Their Marlboro Miles Promotions... They have never been used, except to test them out when I first received them. They have remained in their box ever since. I have everything that came in the box, except for the Owners Manual. I have NO idea where that got to. My Grandson is 7 years old now and I want to give these to him. So, I would like to get my hands on the Owners manual Please Help! Thank you very much for ALL of your time, troubles, and efforts.
smlakegirl19
    New Friend:
I have 2way marlboro watch walkie talkie. I can figure out these thiings. it didnt come with a manual missy
Posted on Dec 31, 2010
  • 2 more comments
  • jcpolston Oct 22, 2011
    Ok my 2way watch walkie talkies will not turn on when they have been charged all day. What do you do with it now
  • johnhills
    johnhills Sep 21, 2012
    @ smlakegirl19: A manual did come with these. I still have mine in mint condition.
  • John Grula
    John Grula Jul 01, 2014
    can anyone give me the specs for the charger? I seem to have misplaced mine...
  • John Grula
    @johnhills
What is the range of the uniden black walkie talkie gmrs 520
  • Pair of GMRS/FRS 2-way radios for person-to-person communication while hiking, skiing, and more
  • 22 channels (8 GMRS and 14 FRS); wireless range of up to 2 miles
  • Auto squelch function shuts off weak transmissions and unwanted noise at range limit
  • Single call alert tone; automatic power save circuit extends battery life; includes 2 belt clips
  • Each radio runs for up to 48 hours on 3 AAA batteries (not included); 1-year warranty
May 30, 2014 | Uniden Black Walkie Talkie Gmrs 520
My cobra walkie talkie doesn't work after 2 miles
You didn't include the model number of the radios, but I suspect you're referring to Family Radio Service (FRS) / General Mobile Radio Service (GMRS) two way hand held radios. The FRS /GMRS types are limited to just 1/2 watt. Base GMRS type radios are limited to 5 watts. FRS is limited to Ch 1 - 14. Ch 15 - 22 are GMRS only, and require an FCC license to transmit. You can read more about FRS on Wikipedia.
Many FRS / GMRS two way radios claim incredible distances on the packaging. I've seen some that claim 15+ miles. Given the low power (.5 watt) that they are limited to transmitting, claims such as those would be under the most optimal of conditions. I can assure you that you or I would never encounter those conditions unless we were in some sort of radio laboratory / testing space designed to obtain these crazy distances. In other words, even in optimum "real world" conditions; these radio should only be expected to work when separated up to only several "unobstructed line of sight" miles (such as across open water of a lake, along a beach, etc. The range of these same radios will be reduced significantly when operated indoors, outside between buildings, where blocked by rocks, trees, metal, etc. The only reason you may have reduced range could be due to a power level selector switch that has been set to reduce the output power of the radio. Other than that, I think you'll find a couple of miles is about all you're gong to get.
Feb 20, 2012 | Cobra Radio Communications
Need instructions for mr250 binatone
Click HERE for the copy of the user manual for this unit.
Jun 15, 2011 | Motorola FV200AA GMRS/FRS 2-Way Radio...
What channel should i set my motorolla walkie talkie to get the best distance? It seem not to wok beyond 1/4 mile on channel 3.
You didn't mention a model number, so I don't know if your radio is an FRS or FRS/GMRS model. GMRS channels have more power output than FRS does, but GMRS also requires a license for operation. Other than that, the frequencies are so close together that there is no distance advantage gained by changing channels. The manufacturer's distance claims on these radios are pure advertising gimmicks - the radios are line-of-sight only, so if there's anything between the transmitter and receiver, the signal will not get through.
Nov 10, 2010 | Motorola Walkie Talkie 2-Way Radio
Need manual for GMRS FRS 04A08 cannot get radios sound on. Do you have instructions?
Hi!
Here is the user guide for the Motorola Walkie Talkie you have.
http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Please save a copy to your hard drive or produce a printout so that you have a hard copy. This will be very useful if you need it again in the future.
Oct 29, 2009 | Motorola FV200AA GMRS/FRS 2-Way Radio...
Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Oct 23, 2008 | Motorola FV200AA GMRS/FRS 2-Way Radio...
Xact Communication X32X-2 2-Way Radio Logo
1,010 people viewed this question
Top Xact Communication Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Xact Communication Radio Communication Expert? Answer questions, earn points and help others
