My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
? 4:57
https://www.youtube.com/watch?v=4o9hWHQkOMM
Sep 1, 2013 - Uploaded by And Justice For All
Quick fix/repair for Kenmore He2 front loading washing machine... a Kenmore He2 front loading washing machine when blinkinglights error code occurs ... How to Clean Front Load WasherDrain Filter and Empty the Water ...
? 3:03
https://www.youtube.com/watch?v=f9uS8_0-pWY
Sep 6, 2012 - Uploaded by GE Appliances
If you have a front load washer with a pump filter, your pump filter may become ... pressed start again but it still stops and the cleanpump light still comes back on. .... Samsung Washing Machine cleaning the pump & coin trap
Hi There. HE2 is a Samsung error denoting a fault with the machine not getting up to temperature. While there's a tiny possibility that the problem is with the relay that powers the element or the main control board its self, 99% of the time this is down to the heating element failing. From what I can tell, the machine takes a fairly generic heating element and you can buy them on eBay around £20. It's a fairly easy fix once you have the element, you can probably find a video on You Tube I would imagine
In the Samsung wd0754w8e "HE2" can mean that one of the two thermostats mounted in the top manifold (wired to the active and neutral wires of the element) is open circuit. One is resettable, the other is not and will require replacement if it measures open circuit at normal ambient temperatures. Both thermostats have been very problematic in my samsung front load washer / dryer.
According to my list of Samsung fault codes 'he2' means that there is a problem with the heater not working ('he1' for instance is overheating).
Sorry but a service call is required ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
