SOURCE: Water in Fridge
Hi gchives.
My own fridge had this problem and it turned out to be a blocked drain at the back of the fridge compartment, just below the cold plate. The water is supposed to condense on the plate and run down to a drip channel, and then through a tube onto the top of the compressor, where it evaporates.
On mine, the tube was blocked with gunge so the water spilled over onto the bottom of the compartment. I got a length of earth wire - the sort used for wiring UK domestic ring mains - and poked it down the tube to clear the gunge away. I then chased it through with some hot water and washing soda and it has been fine ever since.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge.
If they do not, please give me more details so I can try to help you further.
Cheers, D
SOURCE: Water dripping from top of fridge (coil housing?) under freezer.
It could well just need defrosting. It does sound as though the coil in the freezer section is frozen. If you try defrosting it and the problem disappears then you have at least found a temporary solution. If it does rectify it I would closely monitor the cabinet for a couple of weeks to check for a reoccurrence. If it does reoccur then I would suggest contacting a fridge guy so that he can check the defrost circuit. The reason we normally suggest to defrost is incase a door was left ajar and the coil froze up because of this. I hope this is of some help and you seem to be on the right track.
SOURCE: Whirlpool refrigerator w/ top freeezer
It has a plugged defrost drain. You may need to defrost for 24 hours with unit unplugged and doors open. UNPLUG FIRST!! f still leaks, you need to remove floor of freezer, then the back wall of freezer. Remove ice. At center rear under coils is the drain hole that is plugged up. Use hair dryer to melt ice. Pour hot water in this area to uncover drain. With hot water in area, you can put a 1/4 diam. hose or copper pipe in drain and blow into it while pressing down. It will slowly go through ice, clearing drain.
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
SOURCE: refrigerator evaporator fan won't run but compressor working
is the evaporator coil frozzen you may have a defrost problem
