Question about Excalibur. K9-MUNDIAL-SS Entry Level Auto Alarm with Dual Zone Shock Sensor
How to turn kill switch off and see manual and instructions
Posted by whatucizzwha on
Alan H
  • 139 Answers
I am assuming that you want to disable the system temporarily by putting it in valet mode. You will need to locate the valet button; they are usually installed under the dash within reach of the driver. The button should be black and about 1/2" in diameter.
Pressing and holding the button for 3 seconds while the alarm is disarmed will put the system into valet mode. The system will turn the LED light on steady and chirp the siren to indicate that valet mode has been activated. To exit valet mode, press and release the button. The LED will turn off and the siren will chirp to indicate that you have exited valet mode.
The included link is for the manual, see page 8.
http://www.caralarm.com/manuals/K-9/K9-Mundial-ss.pdf
Posted on Nov 04, 2010
Front area dome lights won't turn off killing battery life. where is the relay for this?
Can you manually turn them off by moving the selector switch on the dome to "off" position? If not, the length of time that the dome lights were on may have melted the selector switch and you cannot turn them off except by removing the bulb...and replacing the switch or dome light.......
Apr 14, 2015 | 2000 Nissan Quest
How do I disable the alarm or kill switch on my Alarm
In the installation instructions it will describe which wire in the cars loom to reroute to alarm. Find out and rejoin this wire.
This is considering it is aftermarket alarm
Aug 19, 2014 | Cars & Trucks
Manual kill switch
are you refering to an auto start? if you want to install a kill switch all you have to do is go to your stearing collum, of course your going to take the pannles off, find the big red wire thats main ignition to the switch cut and splice a toggle or a axilary key switch in line that will allw you to kill power to the ignition sutting down the rig hope it was helpfull but still need more info on what your asking
Jul 23, 2012 | Cars & Trucks
Black screens, set checked everything but can not
The only "kill switch" I am aware of is the switch on the DVD compartment door. I don't have your exact model but, on my model, this switch is activated when the door covering the DVD is closed and deactivated when this door is opened (kills the DVD spin and reading laser). Look for a small square hole in the DVD player deck and a corresponding raised piece of plastic on the DVD door.
Oct 07, 2009 | Venturer 3.6" Portable DVD Player
No kill switch
but a photo and instructions would sure help.Are you sure you don't have a yellow? button on the top of the turn signal housing on the left handlebar ? Its kinda hard to press in. edit: sorry I was going from bad memory. Yellow is the horn. The kill switch is grey and on the top/backside of the same signal housing. It doesn't have a lot of off/on feel but if you push it hard enough it works.,,,
Nov 10, 2008 | 2006 Gas Gas EC 450 FSE
Excalibur. K9-MUNDIAL-SS Entry Level Auto Alarm with Dual Zone Shock Sensor Logo
2,089 people viewed this question
Top Dual Electronics Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Dual Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
