Question about 2wire (1000-400108-001) Router
Poor or no connection from 2 Wire router/modem to desktop. Tried new ethernet cable with no success.
Posted by pmcltd87 on
  • 2wire Master
  • 7,733 Answers
Try the user guide --->link.
Posted on Nov 04, 2010
Hp a345w desktop pc dcs server not found conflict
what OS, we can NOT GUESS your operating system.
so where are you , home or star bucks.?
what is your connection, wifi, ethernet, or others?
a desktop pc can have vast ways to get internet.
1: modem dial up (i bet not this, nobody uses this now, 99.9)
2: cable modem, sat modem, fiber modem to ISP
3: USB wifi dongle, on PC and to local router.
4: PCI card wifi. , to router.
5: ethernet wired to router or modem direct. a cable wire. CAT5/6
one can even have direct wired ethernet to the cable modem
or you might have wired to wifi router (2 ways to connect there)
NO OS stated
no connections stated.
my guess is DCS, means DHCP not found, or DNS not found.
lots of causes, but I will not attempt to answer for all 6 ways.
sorry
May 30, 2017 | HP Computers & Internet
I want to plug in another wireless router into my surfboard modem and have the wireless router work as well as the surfboard. Is there a way to do this successfully?
Yes this is possiable. First you need to unplug the power to the Motorola and the new router. Second connect the ethernet cable from the Motorola to the internet port on your second router. This port may be colored in yellow, marked as modem, or the ethernet port by its self. Third connect a ethernet cable from the new router to a desktop or laptop this is only to configure the new router. Next power on the Motorola and wait for the online light to become solid. Then plug in the power to the new router. Give the router about two minutes to obtain ip address from the motorola then try to get on the internet with the pc connected with the ethernet cable. Now you can run the new router setup cd on the wired pc to setup router. Once completed remove ethernet cable to the pc and connect to either network you have and you are good to go. Any questions just ask.
Dec 30, 2010 | Arris SURFboard SBG900 Wireless Router...
I am trying to connect my new router to my laptop,but the instructions say i should connect my pc to the internet by connecting my ethernet cable to the router.my problem is i have only one connection and...
Modem <-- Ethernet cable --> WAN port on router
LAN port #1 on router <--- Ethernet cable --> network-port on desktop computer
LAN port #2 on router <-- Ethernet cable --> network-port on laptop computer
If the router has built-in "wireless" capability, then use the desktop computer's connection to the router to "configure" the wireless adapter, i.e., pick an SSID, and establish a password, and then your laptop computer can use the SSID/password to connect "wirelessly" to the router.
Mar 07, 2010 | D-Link DI 514 Wireless Router (DI-514)
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Hooking up a Linksys dual range router to a 2 Wire cable modem
ok once your internet is resolved you shouldnt need to have any computer hard wired to the router but it should go like this cable from your wall to the modem, then cable from modem to the router, after that you can go wireless all the way just make sure that its all secure and encrypted dont want the next door neighbor stealin your internet
Feb 25, 2009 | Linksys Ultra RangePlus Wireless Routr...
Zoom aDSL modem/wireless router seen but not connecting
Here are a couple of ideas to look at first, assuming you haven't tried them already:
1) Does moving the router help? Sometimes a new DECT phone or a microwave, or even a piece of equipment at a neighbour's house, can interfere with the signal.
2) Does changing the channel on your router help at all? If there are many other networks using the same channel, this might block your own signal.
3) If this does not make any difference, it might be worth checking your security settings.
Nov 14, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Trying to get router to work
that would be a settings issue for the router..the output of the modem should work on usb or ethernet..can you see the router from your desktop management application?
Oct 22, 2008 | Computers & Internet
No internet signal between router and desktop pc.
have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Oct 14, 2008 | Computers & Internet
Ethernet Port failure new router
Check the socket in either the router or the PC. I had the same problem, only with my modem. When I inspected the port, the pins were misaligned, causing it to drop a connection. I corrected mine with a screwdriver, which is not ideal but it works.
Jul 14, 2008 | Arris SURFboard SB5120 Modem
2wire (1000-400108-001) Router Logo
20 people viewed this question
Top 2wire Computers & Internet Experts
efs_perpends
efs_perpends
Mike
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
