Question about Honda Landa PG 3500 PSI Pressure Washer
13 hp honda pressure washer 3000 psi 4gal/min Hard to start and dies out after 20 seconds after the engine gets hot and running after multiple starts the engine will stay running but then dies every 30 minutes
Posted by sholmberg on
Aron Kerr
    Scholar:
  • 45 Answers
There are a couple of things that can cause this problem. The first thing to check is if you are loosing spark. Dying after it gets hot sounds like to stater is failing in the engine. If you loose spark this is more than likely the issue. If you are not loosing spark you need to check the fuel system. Dying after 20 seconds it could also be a plugged main jet in the carb. Another common issue on Honda engines is a faulty vent on the gas caps for engines sold from around 2008 - late 2010. If your gas cap is only about 3/8" thick this is very likely to be your issue. Try running the engine without the gas cap on to see if it still dies. If not that is your problem.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Posted on Feb 13, 2011
Engine will not run but a few minutes at a time
Check your spark plugs, see if they are failing, if they are then your motor is getting to hot. meaning that you either have the fuel mixture set to high or the setting on the spark plugs are not correct causing you to burn hot.
Please rate
Jun 01, 2010 | Honda Pressure Washer PSI 3000
New Troy-Bilt 3000 psi - Very Hard to Hot Start
When you run the unit and shut if off, release the pressure from the spray wand before trying to restart the engine. This built up pressure will cause it to be very hard to start as you have found out. If it does not start on the second pull release the pressure again. Another option is do do what I did on mine. I simply put a pull tie on the handle so I can pull the trigger back and use the pull tie to hold the trigger open. Make sure if you do this, that you remove the high pressure orifice from the end of the wand before attempting to start the engine. Otherwise the pressure will come on abruptly and could injure you or do property damage.
Apr 25, 2010 | Briggs & Stratton Prosumer 20324 Gas...
Northstar PW shuts off hot if washer is moved. Honda engine
Being petrol driven, it may have a mercury kill switch which puts a ground on the ignition circuit stopping the engine if you move it. Perhaps for safety in case you overturn the unit somehow.
Apr 08, 2010 | Northstar Pressure Washer 3000 PSI
Engine quits running after start
It can be probably the spark plug,change the spark plug.
Apr 02, 2010 | Honda Pressure Washer PSI 3000
Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Dec 20, 2009 | Honda Pressure Washer PSI 3000
I have a 3000 PSI Honda pressure washer. The motor
May have sediment buildup in the pump housing, ???
Jun 04, 2009 | Honda Pressure Washer PSI 3000
Honda GX340 11 Hp ..Runs fine until it gets hot , Cuts off and
FIRST...check the engine oil level. Some Honda engines have an oil sensor that shuts off the spark if the oil is low. This would also explain it shutting down when it get hot. Check the manual to see how to tell if the oil level is correct. Also, the oil should be brown and transparent, not black. It may need changing. Post again if this doesn't help :-)
Jun 01, 2009 | Honda Pressure Washer PSI 3000
The washer will run about 2 min. then die. i have checked the oil, air filter and gas. it has good presure when running then it acts like its out of gas by stalling and dieing. Problems with Mi T M 13 Hp,...
It is possible that the oil pressure switch is not functioning properly or you have a lighter oil in the machine than is recommended.
Post a comment if you need more assistance.
Apr 27, 2009 | Honda Garden
% hp Honda Motor runs on choke
Dear LC39B,
Is it possible you are blaming the wrong part of the machine? Did you try the Honda Motor on its own? I am asking , because if the pump of the washer has some fault or a bit jammed, this will demand a lot of power from the Honda. You can try the Honda with no water connection and no gun.
Regarding the Honda motor, you should check the electrical system also. I am saying this because you did not mention it, in your service procedure.
Regards,
MG.
Nov 02, 2008 | Karcher 2500 PSI Pressure Washer
Honda Landa PG  3500 PSI Pressure Washer Logo
831 people viewed this question
Top Honda Garden Experts
JOHN LAPIER
Marvin
Marvin
Tim Venetis
Are you a Honda Garden Expert? Answer questions, earn points and help others
