Question about Cowon System iAUDIO A2 (30 GB) Digital Media Player
Hey, when i starts the cowon a2 it shows a weird red X and it automatically shuts down it self. i tried to connect it to the back USB port of my PC and the PC does not recognize it. what should i do?
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: problem with my cowon a2
Why don't you try to scan your cowon, with your antivirus??? it should work... and so you'll be able to get rid of the troyan.
I started scaning my A2 a while ago (I have kaspersky ) and it worked.
Posted on Oct 08, 2008
golu_fixya
shivam raj
  • 213 Answers
SOURCE: Cowon D2 repair
hello you can
see in this website
don't forget to rate
http://www.cowonglobal.com/product_wide/product_D2_feature.php
Posted on Jul 04, 2009
Cowon iaudio 10 frozen
Hi. I had problem like this, now resolved. My device is iAudio 9+ otherwise it's not matter.
You can find some solutions on the web but... maybe you can not do proper result first or second time. It comes because of some differences for so lot of devices.
I used this method.
How To Recover your Bricked J3 using Tcctool iAudiophile net Forums
Only one way working for me.
1. Prepare drivers and firmwares. Tcctool and Windows drivers for USB flashmode. Latest FW for your iAudio from Cowon Korea site. Unpack all files/folders into special directory in root of your Hard Drive (c:\COWON for example).
2. Boot your PC in compatibility with non-authorised hardware mode. Press F8 button when PC loading and choose Drivers signature disabled mode.
3. Turn off your iAudio with reset button. Press both M(enu) and VolUp buttons and boot on power. Screen doesn't fire but device standing up in flashmode. Connect USB cable to device, then to PC. On Windows Device Manager you must find new Unknown Device. Install drivers manually from your specific directory.
4. Run on PC new task CMD, e.g. terminal window. Change work directory to your specific, f.e. cd c:\COWON
Run execution tcctool.exe -d cowons9 "name of your FW file"(without quotes).bin
Attention, your FW file (iaudio9P_fw.bin for me) must be in same directory with executable tcctool!
5. After flashing your iAudio must be connected to PC immediately as USB flash device. So you must copy all firmware files (named *.bin) to root of your Cowon device memory. Then reboot, your player must updating firmware and working fine. If still no, try use tcctool to boot on once more, then reboot normally. Copying FW files again doesn't required.
Hey you don't give up!
Mar 31, 2014 | Cowon Iaudio 10 16gb White
Can't charge battery
If you are trying to charge it through your PC usb ports and it is a laptop, the usb ports may be shutting off on you to conserve power, depending on your power preferences. USB takes a long time to charge as well.
Mar 12, 2014 | Cowon iAudio M3 battery 1100 mAh
Sorry to say that i couldnot get my answer.oncemore my question is i have a sony handy cam HDR-CX230.it can be recharge via USB port and photo can be transfered.previously i charged my handycam in my...
First off I would buy a converter that allows you to plug your usb cord into it and then it plugs into an AC outlet. It will charge faster. Second, it sounds like when you PC is trying to recognize the hardware you have plugged into the usb port it isn't finding any software associated with the device and is for some reason restarting. If you received a software disc with your camcorder, try loading it on this PC and see if that fixes the problem.
Jan 21, 2014 | Sony 8GB HDR-CX230 HD Handycam Camcorder...
Hi. When i connect the USB cable the PC studio starts however it does not read my phone and after a minute it shuts down automatically. Pls help as not able to sync data with PC.
hi :) that have a reason of the pro. have your water damage before ?? maybe the port was dirty inside,make phone shut down. try send for technician have a check or servis.
Jul 06, 2010 | Samsung SGH-D900 Cellular Phone
Cowon D2 repair
hello you can
see in this website
Jul 04, 2009 | Cowon System Cowon D2 Digital Media Player
Hey please please help me when i put my cowon a2 on it just shows the logo and then a red circle with a cross appears then it just goes off
Plz format your device by pluging it into computer... then it would get good as new and also you can recover your data by keeping back up or just recovering it from any software .. recommended DATA doctor recovery
Jun 23, 2009 | Cowon System iAUDIO A2 (30 GB) Digital...
Problem with my cowon a2
Jun 09, 2008 | Cowon System iAUDIO A2 (30 GB) Digital...
How do i enter usb 2.0 mode and how do i download the updater
your pc will; if it's reasonably new, have USB 2.0 ports and that is probably what you need to connect the player to for transfering files, it's not a mode thats within the player that you can change, it may work with usb 1.1 if it does it will just transfer at a slower speed that's all, if it's a laptop thats about 4 years old it should have USB 2.0 ports, but some dont show, that goes for both pc and laptop, so try connecting in a different port to see if it connects. The Sansa updater will probably only be used when there are updates available and will be automatically advised when you are on line.
Jun 25, 2007 | SanDisk Sansa e250 MP3 Player
Cowon System iAUDIO A2 (30 GB) Digital Media Player Logo
138 people viewed this question
Top Cowon System Audio Players & Recorders Experts
Ekse
Tom Chichester
Nanny
Are you a Cowon System Audio Player and Recorder Expert? Answer questions, earn points and help others
