Servis 23 in. M4308 Free-standing Dishwasher Logo
Posted on Nov 03, 2010
Why wont the water empty? - Servis 23 in. M4308 Free-standing Dishwasher
1helpful
My front loading machine does not appear to be pumping water in a light flashes H20 and beeps
? im confused are you saying its not filling with water or its not emptying of water , if its not emptying of water , yes its true the pump in it is driven by a motor and yes they d go bad and yes if the pump wont turn then yes it wont empty out , this makes sense to the blinking light of water detection you see ? ohh and most times the pump and motor are all one assembly , if it wont fill with water then you need to ck the inlet valves they get clogged or go bad too ) there is no motor that is assoc with these valves that I know of
Help my machine hotpoint ultima wma 60 wont empty water tried 5 times water sitting there had turn machine off
p my machine hotpoint ultima wma 60 wont empty water tried various times water sitting there had turn machine off
Hotpoint wma13 wont empty, think pump is blocked
Yes,
The water pump most be clugged and/or defective.
Whirlpool washer AWM 5145/5 water wont drain/stops on B
I had same problem twice, the first time there was a sock in the filter at the front adjoining the pump, the second time a sock had got in the pipe under the drum which is more awkward to get to but is possible if you have the tools to remove the back plate and are ok at diy, there is a spring tension clip on the pipe which comes off quite easily with a pair of pliers.
1helpful
Washer wont empty water
Hi meeey,
I'm Harvey the Master Plumber.
Your problem is: washer wont empty water
If the motor runs but it won't empty then the pump needs replacement. If the unit washes but the motor won't come on to empty then you have a control problem. Either way I don't recomend this repair to the average homeowner. You might consider utilizing our Repair Directory to find a repair man.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 • Dishwashers
Hotpoint dwf 30 - Water wont empty
if the drain is plumbed into a spigot on the sink trap, then this spigot is blanked off to prevent water coming out when you empty the sink. remove blank
Aug 31, 2008 • Dishwashers
Washing machine wont empty
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Top Servis Dishwashers Experts
Mike Cairns
Mike Cairns
john h
Are you a Servis Dishwasher Expert? Answer questions, earn points and help others
