You might try holding down the power and home buttons at the same time.
Wait until you see the silver apple. Thats what I did when mine
wouldn't turn back on.there is an easier way instead of just guessing....
when you plug it into any form of charging source...just completely shut
down your iphone...and leave it there for how ever long it takes to
charge...(to be able to use it again is about 30 minutes)depends on your
energy sourceFirst open iTunes and Conect your iPhone cord to your computer, but do
not plug it into your iPhone. Then press and hold the home button on
your phone while conecting the iPhone cord into your iPhone continue to
hold down the home button. Then click restore in iTunes
From what Ive read, you its not possible to connect an iPhone to another cellphone via Bluetooth. You can only connect handsfree, speakers etc via the Bluetooth on the iPhone.
It is normal to get incompatible devie message when you attach your iphone to dock because you don't use apple dock. I have 5 different brand portable speakers, charging docks. And all of them give same message when i attach my iphone 4 to dock. When you press "ok" on your iphone screen, it should start to play your songs. You don't need to use your iphone at airplane mode.
You may have problem with your iphone dock conncector cable pins. If audio related pins are damaged, you can not use any external iphone speakers with your iphone4. In order to test your sonic integrity tube pod; try another ipod or iphone on its dock. If it gives same result, you may need to change dock connector unit on sonic integrity tube pod due to damaged pins. If it works; iphone 4 dock connetor cable of your iphone 4 needs to be replaced.
There is a 3/4 inch tube from the exhaust manifold to the EGR valve located need the intake.Along that tube are two small pipes that are conected to the senseor, one is lager than the other, note. it may be aluminum or plastic, so pay close attention to tube conections.
use the 6 and 9 vlts 600 ma. transpormer conect the 6 vlts AC to heater 1 and the common grn to heater 2 the primary conection use 10 W. bulb with riceptacle conect the one line of the bulb conect to G2 of screen board back of the tube and the other line to RGB first conect R the 10 W. bulb light blinking if the bulb light steady finish. conect to the G if the light steady conect to B. finish good luck god bless
