What would make the frount breaks squeak on a 1997 buick lesabre? we changed the breaks had rotters turned. you can put your food on the break peddle and the squeaking will stop, just lay your foot on the peddle. please help?
Brake pad i them selves are a fairly easy job. However, to do the job correctly the rotters must be turned on a lathe. If you take the rotors off and bring them to a shop then you should change the barrings, the barrings must be packed with grease and reinstalled all this is simple but takes skill. you can also just buy new rotors and then just turn the old ones at your leasure for use in the future.
But that said,
to change the pads you will need a "C" clamp, a screw driver and some break cleaner. open the hood and take the cover off the master break cylinder. if you can remove some of the fluid. as you depress the wheel cylinder fluid will build up in the master cylinder resivware and over flow, you might be able to catch this with rags. Don't let this get on the paint. You may also need a set of allen wrenches. use the allen wrench to remove the two bolts that hold the break assembly in place, with the bolts all the way out remove the assembly by rocking it back and forth. once off remove the pads (pay close attention to any clips and the position of the pads there could be a difference between the inside and out side, left or right). after the pad are off place the "C" clamp over the puck and slowly tighten until it is all the way in, just hand tight, don't crank hard or fast, take your time. this is the easy part. after it is in remove the clamp and install the pads in the revers order mentioned, tighten down the bolts real tight. after all the pads are replaced the brake fluid will look real yucky. and rusty, pump the break peddle and see if you get a good peddle. you should as long as you did not remove the lines. use the break cleaner to clean off any grime or dust on the rotters and pads.
Does this elbow come from the intake and go to the alternator bracket. It is the heater outlet. It is available aftermarket at about every parts store. They are made of plastic and tend to crack and break.
More likely this is a wheel bearing or CV joint than suspension components.
One good indication is if, when your making a right turn or accelerating, there is a shudder or shaking in the steering wheel then its likely a wheel bearing.
Another good indicator can be found when you jack up the suspicious wheel. Put one hand on the top of the wheel and one on the bottom and pull back and forth. If the wheel makes a clunking noise and moves in either direction, then wheel bearing is shot.
The only thing that will cause this noise is a worn out or dry running (caused by torn or damaged grease boot) Constand Velocity Joint or CV joint for short. this part is on the front dive axles just behind the wheel.
Does the abs light come on when pulsating? if yes then maybe you have a bad ABS sensor or it just the sensors cleaned . Where they turned under spec .which means more likely to heat up and warp or crack
