Computers & Internet Logo
Posted on Nov 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When trying to restore my u series 9, (ST3160022ACE) ultra ATA 160 gig hard drive I get this message: Restore was not successful. Remove any USB or Extra Hard drives taht are connected. I have no USB or Extra Hard Drives connected. What should I do to get past this?
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Nov 04, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2555223
Points
31058
If by "restore" you mean that you are reinstalling Windows onto the disk-drive, to restore Windows to the "as-shipped-from-the-factory" condition, then a failure of that operation can be caused by either of three conditions:
* I/O errors reading files from the CD/DVD disks (due to dust/fingerprints on the bottom of the disks),
* I/O errors writing files to the disk-drive,
* an intermittent problem with the computer's motherboard or RAM, causing "random" failures when using the computer.
So, on another computer, take the CD/DVD disks, and try to copy the entire contents (namely up to 4.7 GB) onto the 'C:' drive, watching for any "I/O errors" during the file-copy operation.
If the file-copy completes successfully, then the copy of the files can be deleted.
If no errors occur, then it's time to suspect that the disk-drive itself is failing.
Buy a new disk-drive, and disconnect the old disk-drive, and connect the new disk-drive,
and restart the "restore" operation. If the "restore" fails on the new disk-drive,
then it's time to suspect that the motherboard has a problem.
How can I recover my proffile
Thedata recovery packis made up of two programs: Hetman Photo Recovery, Hetman Uneraser. You save up to 20% on the order price by buying the programs in a single package. The package allows you to restore important office documents, digital photos, archives, video and audio files, which have been lost by accidental deletion from your drive.
Hetman Data Recovery Pack restores data from internal and external hard drives, camera and mobile phone memory cards, and USB memory sticks. Instant data recovery software recover all your deleted or logically damaged data from FAT and NTFS volumes.
You can download the data recovery pack to assess its ability to restore your required data. Data from recovered files found following a hard disk scan is guaranteed to be restored, once you purchase the program.
Key Features:
· Restoration of information from internal hard disks and external IDE / ATA / SATA / SCSI disks and logical partitions, and restoration of USB storage media;
· Restoration of data deleted from memory cards for digital cameras, mobile phones, smartphones and PDAs;
· Restoration of files lost following formatting of logical partitions FAT and NTFS (supports NTFS compression);
· Restoration of data accidentally deleted from USB memory sticks (including manufacturers Jetflash, Apacer and Sony).
Format a sandisk ultra 8gb in a kodak easyShare v550
if now you can see your usb drive there might not be any need to do the following
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps
2helpful
Set inspiron 6000 to factory settings, how do i do it?
To Restore Windows XP
  • 1
    Back up all of your data. Typical items to consider when backing up are: email, address book, personal documents, pictures, videos, music, favorites and desktop items. (For more information on how to back up your private data see the link below.)
  • 2
    Remove all external peripheral devices, including USB-connected devices.
  • 3
    Turn on the computer. If the computer is already on, reboot it.
  • 4
    Press and hold the "Ctrl" and "F11" keys simultaneously when the Dell splash screen appears. The "Dell PC Restore by Symantec" window will appear. Click "Restore."
  • 5
    Click "Confirm" at the warning message stating that all data will be lost. A "Progress" window will appear. Once the installation process has finished the message, "The system recovery process was successful" will appear.
  • 6
    Click "Finish."
  • To Restore Windows Vista
  • 1
  • 2
  • 3
  • 4
    Press the "F8" key when the computer starts. If you see the Windows logo then you were not successful in entering the "Advanced Boot Menu." You will have to try again. If you are successful then you will see the "Advanced Boot Menu."
  • 5
    Select the "Repair Your Computer" option and press the "Enter" key.
  • 6
    Select the language you would prefer and click the "Next" button.
  • 7
    Log in and press "OK." You do have to have administrative access to perform this action. Only administrators are able to restore the computer to factory settings.
  • 8
    Click "Dell Factory Image Restore." The "Dell Factory Image Restore" window will appear. Click "Next."
  • 9
    Click the check box that states, "Yes, reformat hard drive and restore system to factory condition." Click the "Next" button.
  • 10
    Click "Finish," when the restore has finished.
  • Good Luck please rate 4 thumbs up and please leave a testimonial
    1helpful
    When I boot my Dell D600 it get a blue screen and i am not able to log into my computer
    In this case, we need to reset the computer back to factory settings.
    here we go...this process will cause data loss.
    1. Remove non-essential peripherals
    like
    a) Scanner
    b) Printer
    c) Modem or Network cables
    d) Personal Digital Assistant (PDA)
    e) USB flash drive or other external Hard Drive
    f) Any other external devices (e.g., USB-attached devices)
    g) Remove the computer from the docking station, if you are using one.
    2. Turn on the computer.
    3. When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
    NOTE: Some systems like Inspiron Mini 9 (910) do not support System Restore as they do not have <F11> nor any substitute.
    4. In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
    5. When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
    The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
    When the restore process is complete, the following message will appear:
    The system recovery process was successful.
    6. Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
    The software is now installed as it was when the computer was first received.
    2answers
    Dell inspiron 6000 laptop restore to fACTORY SETTINGS WAND TO DOWNLOAD A RESTORE
    If you have the restore CD that came with it, then pop that in and it will walk you through the process, If not, then I know that those laptops are a few years old...follow this:
    Dell created its own utility program for Windows Vista. Restoring to factory settings will reinstall Windows, Dell proprietary utilities and drivers, other third party drivers and all default settings. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
    To Restore Windows XP:
    Step 1: Back up all of your data. Typical items to consider when backing up are: email, address book, personal documents, pictures, music, favorites and desktop items.
    Step 2: Remove all external peripheral devices, including USB-connected devices.
    Step 3: Turn on the computer. If the computer is already on, reboot it. Step 4: Press and hold the "Ctrl" and "F11" keys simultaneously when the Dell splash screen appears. The Dell PC Restore by Symantec" window will appear. Click "Restore."Step 5: Click "Confirm" at the warning message stating that all data will be lost. A "Progress" window will appear. Once the installation process has finished the message, "The system recovery process was successful" will appear.
    Step 6: Click "Finish."
    Step 1
      Step 2: Remove all external peripheral devices, including USB-connected devices. Step 3 : Turn on the computer. If the computer is already on, reboot it. Step 4: Press the "F8" key when the computer starts. If you see the Windows logo then you were not successful in entering the "Advanced Boot Menu." You will have to try again. If you are successful then you will see the "Advanced Boot Menu." Step 5: Select the "Repair Your Computer" option and press the "Enter" key. Step 6: Select the language you would prefer and click the "Next" button. Step 7: Log in and press "OK." You do have to have administrative access to perform this action. Only administrators are able to restore the computer to factory settings. Step 8: Click "Dell Factory Image Restore." The "Dell Factory Image Restore" window will appear. Click "Next." Step 9: Click the check box that states, "Yes, reformat hard drive and restore system to factory condition." Click the "Next" button. Step 10: Click "Finish," when the restore has finished.
    4helpful
    2answers
    Media test failure, No bootable device, insert boot disk.
    Media test failure, no bootable device error message means the hard disk has failed, therefore cannot boot up.
    If reseating the hard drive doesn't fix your problem then replace the faulty drive and install Windows on the new drive to get the computer operational again.
    Seagate 160GB SATA Hard Drive Installation.
    Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
    Top Seagate Computers & Internet Experts
    Sean Wright
    Sean Wright
    Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
