Question about Pitney Bowes 9920 Plain Paper Fax
How do you set the time on a 9910 PB Fax? - Pitney Bowes 9920 Plain Paper Fax
Posted by eric_james2 on
Vicki Cook
You need to go into Set Mode and User Parameters
To do this press Function key and 7 to get Set Mode
Then press 1 for User Parameters and set, the first option is to set date and time, use the number pad to do this.
Posted on Feb 02, 2011
Problem when powered on it beeps and won't sew you singer won't sew and it beeps when powered on singer quantum 9910
Try the Troubleshooting section of your manual:
Singer 9920 Instruction Manual Helpful Hints
Check that the machine is not set to wind a bobbin.
Remove all the thread and rethread from the beginning.
Mar 25, 2017 | Singer Quantum 9910 Computerized Sewing...
I bought a new D252GRGI pump and when i took the old one off the reducer gear stayed on the motor shaft. How do I remove it?
You will need to use a gear puller. This often happens in corrosive environments but it isn't that tough to tackle. Just make sure you use a two arm puller and it will pop right off. It might not hurt to spray PB Blaster on the center of the shaft the night before.
Sep 10, 2013 | Hypro Diaphragm Pump D252GRGI 3/4...
I have a Singer 9910 machine and I cannot get the thread tension correct. Every time I try and sew it bobbin thread is showing on the top.
Turn the tension knob to the left. Look at your manual and if you cannot find it, go to singerco.com and download it. Do not turn the knob too much each time or you will get it all messed up. Just a small amount each time.
Sep 09, 2010 | Singer Quantum 9910 Computerized Sewing...
Need program code and instructions for a memorex DVD player to program my One For All URC-9910 to a Memorex DVD player
The original instructions do not list Memorex as a maker of DVD players.
One forum says it might be DVD 0695, 0831, or 1270, but does not say if that was before or after a code upgrade from One For All.
Search for URC-9910 to find a complete instruction manual.
Also try "SEARCHING FOR YOUR CODE", although tedious, it may work:
1. Turn on the TV and or device to program.
2. On the URC-9910 remote control, press and hold
SET until you see the display change from the
current device and time to [CODE SET].
NOTE: To exit programming at any time, press EXIT once or
allow 30 seconds of inactivity to lapse.
3. Press the DOWN key on the 4-way pad once until you see the display change to [MAN SEARCH].
NOTE: If you go past [MAN SEARCH], press the UP key one or
more times to return to it.
4. Press SELECT once to begin programming.You will
see the display change to the last-selected device
and its code (e.g., VCR and 0035).
5. Press a desired device key once (e.g., DVD).You will
see the display change to the desired device and the
first code in the manual search list (e.g., DVD and
0047).
6. Aim the URC-9910 remote control at the device
(e.g., DVD) and press SELECT once.You will see the
LED (red light) blink and the (IR) icon flash
indicating IR codes are being transmitted.
7. If the device (e.g., DVD) turned off, skip to the next
step. If it did not turn off, aim the URC-9910 remote
control at the device (e.g., DVD) and press the UP key
once to advance the manual search to the next code
(e.g., DVD and 0054).Again you will see the LED (red
light) blink and the (IR) icon flash.
Repeat this step as often as needed until you find a
code that turns off the device.
8. To save the working code, press SELECT once.The
display will confirm your entry with [SUCCESS] and
then [EXIT SETUP].
Aug 10, 2009 | One For All URC-9910 LCD Remote Control
Paper jam on Pitney Bowes 9910
try a new toner, if not it could be fuser
Feb 17, 2009 | Pitney Bowes 9920 Plain Paper Fax
Pitney bowes 1530 / INCOMING fax date/time stamp
For the UF-595 here's how you turn the fax stamp on:
Function + 7 + copy/set for enter
scroll to option 4 + copy/set
Hit 04 + copy/set and enter number 2 to turn the fax stamp on. 1 turns it off.
Scroll to or enter 28 and choose 2 to turn the fax stamp on for faxes stored in memory for later use.
You hit the "clear" button to wipe out the current number before you enter 2 or 1 for the new entry.
Jan 08, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Fax is on pulse dial
Go to the Utility menu, select "Administrator Settings" (password required) from there , fax settings, telephone line. In here you should be able to set the dialing method. There should only be 2 options, just pick the other one. (PB is for tone i believe)
Oct 31, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Pitney Bowes 9920 Plain Paper Fax Logo
237 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Marvin
Marvin
Tareq Bin Mostaq...
Tareq Bin Mostaq...
john h
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
