Question about Samsung HL-S6187W 61 in. HDTV
No picture, replaced lamp on HL-S6187W. TV makes a audio sound when I turn it on. Lamp does not light.
Posted by herbert_gree on
Walter Cardenas
    New Friend:
  • 129 Answers
Did you replace the lamp? Was the Lamp original? Some time if you dont replace the lamp with original you are going to have this issue. Is there any sound. If you have sound and no picture is the Color Wheel.
Thank you,
Posted on Nov 03, 2010
I have a samsung hl-s6187w 61 inch and it keep shutting off.. the screen goes black but i still have sound for about 5 sec then shuts off.. can anyone tell me what the problem is?
I doubt it's the color wheel. When our wheel went bad the TV didn't come on at all. It could be the lamp. Try reseating it first. That fixed a problem the first time for us. Later we had to replace the lamp because the TV was getting dark. It could also be your ballast, but we've never had to change that. I'd start with the lamp.
Feb 16, 2015 | Samsung HL-S6187W 61 in. HDTV
Samsung HL-S6187W no picture, no sound, no start up jingle... Lamp is on, can hear color wheel turning. Already tried new lamp, new dmd chip, and new dmd board... Now what?
I have had issues where the digital board and also the analog board have been known to cause weird symptoms like that. Did the picture ever freeze any time before this isuue appear?
Oct 20, 2012 | Samsung HL-S6187W 61 in. HDTV
Hi, at first my tv starting dimming over time, then finally no picture at all. Took out the lamp and housing it looked burned so i ordered a new one. 3 days later it came and i installed it, about 20 later...
your tv is not getting enough ventilation. Ne of your fans inside the tvis provably bad and will need to replace. also you should make sure the inside is clean and that there is enought space for air to circulate around the tv.
You can get get parts for this tv at www.interliquidparts.com
Jul 08, 2011 | Samsung HL-S6187W 61 in. HDTV
I cleaned out my Samsung hl-s6187w and put everything back together and now it doesn't turn on. It makes a beeping noise like fast morse code and keeps cycling the power trying to turn on. The ballast gets...
Tv projection lamp inside the tv less than 2 years or so?Yes than the tv projection Lamp is good.You have this tv like 3 or 4 years already?The tv colors wheel even have been replace at leat once?No the tv probally require replacing the colors wheel these tv have to replaced the colors wheel every now and than.
Apr 14, 2011 | Samsung HL-S6187W 61 in. HDTV
Our tv was shutting off within 10 min of turning it on. 3 lights would then start blinking. We replaced the lamp today and it is still turning off within 10 min of being turned on. We checked the door to...
If turning the lamp on fails, the set automatically tries turning the lamp on 3 times. If all attempts fail, all LED's on the front panel will blink. Check the lamp and the ballast and replace them, if necessary.
Check lamp fan too, make sure fan is rotate smoothly. Thanks.
Jan 24, 2011 | Samsung HL-S6187W 61 in. HDTV
I have a SamSung HL-S6187W DLP whide screen tv
You need to replace the light tunnel.you will need to remove the lamp and color wheel along with the lamp housing and fan housing to replace it .If you are not comfortable taking things apart you might want a tech.
Nov 30, 2009 | Televison & Video
Lamp goes off and tv shuts down after lamp replacement
CK FAN on LAMP,or you could have problem with Ballast.
Aug 11, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
TV turns off by itself
Check the interlock switch on the rear lamp cover. Sounds like the cover might not be seating completely, allowing this safety switch to shut the TV off. When you remove the cover, it's just to the left of the big black plastic ventilation guide for the lamp, and it's a little tiny blue lever that moves up and down. Make sure the wires going to this switch are OK (not pulled out or 'hanging by a thread').
Jun 09, 2009 | Samsung HL-S6187W 61 in. HDTV
Samsung HL-S6187W 61 in. HDTV Logo
218 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
