If you post a picture that would be easier and I may be able to locate the cable for you. Other than that there is a couple of places to check. One would be LPAV out of St. Paul, MN. They deal with nothing but used/older equipment and have tons of that stuff. The other would be allied electronics. If they do not have a premade cable but have the ends and you need further help I could probably make one for you.
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
Inspect the pins inside the network connector. They have to be even and stright. Sometimes people put there a phone cord connector and it bends pins 1, 2, 7 and 8. To recover use a needle with slightly bended tip. Hook the pin with the bended tip and pul until strightened.
Every Sony LCD TV comes with VGA port (15 pin D-Sub connector) assuming you have LCD T. You can connect your monitor cable to this port & select the input on TV from the menu.
The difference between the 5100 and the 6400 is the video card inside. The 5100 has an ATI videoand the 6400 has Intel graphics. Try going to the Intel site to download new drivers for the Intel graphics. There is a driver checker on their website.
your question is not clear but I think u want to watch screen of Computer in sony bravia LCD/So u can better/use a video card for ur computer/Ex:-e-GeForce 6200 256 MB DDR2 PCI Graphics Card or
Stealth Radeon 9250 256 MB DDR PCI Cinematic 2D/3D Graphics Card/Try these video cards to connect ur computer to sony tv/Try it out or else u can reply back
Reseat the video cable connection under the keyboard, and see if the lines go away. If not, connect an external monitor, see if the lines show there. If the lines do not appear on the external monitor, then replace the LCD. If they do appear on the external monitor, replace the motherboard
If you want to set up tv channels in your tv, connect antenna cable in RF Input at rear of tv, go to tv menu and select preset, then press auto-preset and rest will do tv itself.
Not really, it could be the LCD ribbon, LCD inverter. Also does the system power up? Like does the fan spin? And is there a Hard Drive in it or not, Sometimes the Hard Drive pin connector will do that. " Not The Hard Drive, Part that Hard Drive Pins plug into" If you want me to see about fixing it for you, you can send it to me and I'll see about fixing it. I mostly get trouble with Screens from the Gateway Brand they mostly have the LCD Issues. But I do mainly repair for IBM ThinkPads but also do other brands aswell.
IBM, DELL, Compaq, HP, Gateway, Toshiba, Sony, Acer, emachines and fujitsu. All you will have to pay is shipping.
Thanks...
