Question about Philips 50PL9126D/37B 50" DLP TV
Makes a whining noise when you turn it on - Philips 50PL9126D/37B 50" DLP TV
Posted by smileyjames0 on
Josh Whitehead
    Genius:
  • 1,148 Answers
Phillips website support
Posted on Nov 03, 2010
1999 Pontiac Sunfire 5 speed won't start. Replaced spark plugs and checked ignition coil (fine). Sounds like it wants to turn over but makes a "whining" noise. Please assist. Thank you!
Is the engine turning over with the key in the start position? If the engine is not spinning over and you hear a whining noise, the starter is not engaging the flywheel. If the engine is turning over with the starter engaged, the engine has most likely jumped time that creates low or no compression which results in the whining noise.
Mar 03, 2015 | Pontiac Cars & Trucks
2006 Mitsubishi galant 3.8 v6 won't turn over at
Sounds like your starter is junk replace starter
Oct 11, 2014 | Cars & Trucks
How do i fix the whining noise my 2009 kia sorento makes
may be your power steering pump whining. Check fluid first, then if it's up, start the car up and have someone turn the wheel back and forth a few times. Listen to see if there is more or less noise when this happens. Does the noise go away after it warms up?
Jan 27, 2013 | 2009 Kia Sorento 3.3
Chevrolet k1500 whining noise
There are many possibilities that can cause car to make noise.
Its actually from where the noise is coming from.Front end or rear end.From engine area or from inside from steering or from breaks.
There are N-number of possibilities for the car to make whining noise or any other kind of noise.
For step by step troubleshooting these problem,i suggest you to refer the help links mentioned below.Its a complete solution with proper explanation to identify the cause of problem:------
Click the link below:-----
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
These will help.
Thanks.
Nov 28, 2012 | Chevrolet Silverado 1500 Cars & Trucks
I have a 2001 pontiac grand prix gt and it makes a squealing noise, and when i accelerate it gets louder and more whiny. I have replaced the belt and it still makes the noise. If the car is started and not...
It sounds like a belt thats slipping. You have a sticking puley somewhere, take off the belt and rotate all of the pulleys. Usually its an AC compressor pulley so pay special attention to it. The whining noise that it makes while turning, is it the same as the squealing noise? If so it could be a problem with the pump, check the fluid level and see if its an odd color or has an odd odor (like burnt or black). Hope this helps!
Nov 26, 2010 | 2001 Pontiac Grand Prix
I have a loud whining noise coming from my ac compressor. i have a 98 cadillac deville and it makes the whining noise even if the ac is off. it makes that noise the whole time the car is running
The A/C compressor constantly turns because the pulley is connected into the serpentine system. The whining noise is pretty indicative of a low charge in the A/C system. I would start by having your A/C pressure checked and charged if needed.
Jul 03, 2009 | 1998 Cadillac Seville
Car makes a whining noise when turning left or right.
hi,if you turn the steering wheel in pull position,left or right it's normal to have whining noise,the system is sefl-bleeding if there is air ,ty
Mar 26, 2009 | 1999 Mercedes-Benz Mercedes Benz Sl Class
Whining noise
Could be a few things:
Belt slipping- adjusted through tensioning bolt on bottom of power steering pump
Pulleys- take off belt and hand turn pulleys. Find one that gives resistance and possible makes the whining noise. It's probably the idler pulley.
Feb 12, 2009 | 1994 Jeep Cherokee Country
Kenmore washer makes a whining noise
The whining noise is usually caused by the pump. Try replacing the pump. Or cleaning it out.
Feb 01, 2009 | Kenmore 24032\24036 Top Load Washer
Philips 50PL9126D/37B 50" DLP TV Logo
201 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
