Question about Dell V313w AllInOne InkJet Printer
Every time I try to print, there is an error report that says to "enable bicommunication" in the printer properties. After I do that and try to print, the message is still there. I have rebooted my computer, uninstalled and reinstalled, and that message still pops up. Help?
Posted by spitbath on
CPCI
    Genius:
  • Dell Expert
  • 1,325 Answers
Trying to print to a dell photo aio printer 964 from my laptop and it keeps telling me "communication not available; the printer cannot communicate with the computer; please turn on enable...
Bidirectional Printing - A means of printing by a computer printer which prints one line from left to right, then the following line from right to left. Such printing is faster than printing in one direction only, as there is no need to wait for the carriage or other imaging mechanism to return to the left margin before starting a line.
how to enable bi-directional printing.here's how:
  1. -click on start
  2. -click on printers and faxes (control panel->printers and faxes)
  3. -right-click on Dell Photo All in One Printer 964 All-In-One icon
  4. - click on properties
  5. -click on ports tab
  6. -down at the bottom there's a small box before bi-directional support
  7. -tick the box to enable it then click apply,ok
  8. -try printing again
note: in vista , printers and faxes is printers.in win 7 ,it's devices and printers.
and properties in win 7 is printer properties
Jun 05, 2011 | Dell Photo 964 All-In-One InkJet Printer
Problem printing MS access report on SEP 350PLUS printer
when you change the paper size do you click--- apply--- that is necessary.
Oct 13, 2008 | Office Equipment & Supplies
I have hp lj 4100n printer in my office. this printer is been used for backup. today we saw an offline problem. we just did basic thing like right click on printer icon make seclect printer on line and...
Thank you for contacting FixYa with your printer inquiry.
HP Jetdirect and Embedded Jetdirect Inside Print Servers - A Printer Reports Being Offline or Out of Paper A printer using the HP Standard TCP/IP Port reports being offline or out of paper, even though the printer can be pinged, can display the embedded Web server, and is not out of paper.
  1. Open the Printers or Printers and Faxes folder.
  2. Open the Properties of the printer and the Ports tab.
  3. Click Configure Port .
    This is the most common cause. Hope this helps helps. Please keep us updated and remember to rate this answer. TF
Jan 18, 2011 | HP LaserJet 4100 Printer
Printer does not print and 2 messages appear: 1)
Enabling bidirectional support Windows 7 / 2000 / XP / Vista:
Access the Printer Properties:
For Windows 7
  • Click the 'Start' button from the bottom left of the Windows screen, and then click on 'Devices and Printers'.
  • Click your right mouse button on the listing for your printer, and then select 'Printer properties' from the menu that appears.
For Windows Vista
  • Click / Select the 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, click 'Printers' directly from the 'Control Panel'.
For Windows XP Home Edition
  • Click / Select the 'Start' button from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
  • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
For Windows XP Professional Edition
  • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
For Windows 2000
  • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
In the printer's Properties window, select 'Ports', then 'Enable bidirectional support'
SECOND QUESTION:
ERROR LCD: The type of print head is incorrect. Insert the correct print head
Solution: Reseating the MP500 / MP800 print head
Reseating the Print Head Reseat the print head to correct print issues or clear an error. Reseat the Print Head:
  1. Confirm that the printer is powered on and press the button. (The paper output tray will open.).
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
  5. Raise the print head lock lever.
  6. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles , electrical contacts , or ink supply ports . Doing so may cause printing problems.
  7. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  8. Insert ink tanks into the print head.
  9. Press the mark on the ink tank firmly until you hear a click.
  10. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    The ink tanks are installed properly.
    The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  11. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
  • On: The printer is ready to print.
  • Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • Off: An error has occurred and the printer is not ready to print.
I trust this is helpful. Please express appreciation.
Dec 10, 2010 | Canon Pixma MP800 All-In-One InkJet...
Won't print. Green Light Flashes.
Waste ink absorberfullor platen waste ink
absorber full Pressing the OK button
will clean the error, and
enable to print.
In repair,
<Replacement of Ink
absorber kit
<Replacement of Platen
waste ink absorber
Waste ink absorber full
warning (service call
error) may appear.
Oct 08, 2009 | Canon PIXMA iP1600 Printer
Ink out reported as Communication Error.
Try reseating all cartridges, and power cycling the printer...
May 07, 2009 | Epson Stylus D88 InkJet Photo Printer
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
Wont stop printing TX report!
moz-screenshot.jpgmoz-screenshot-1.jpgmoz-screenshot-2.jpgmoz-screenshot-3.jpgHere are some of the instructions you'll need, but you can also find more assistance by accessing the online Canon support site and searching the exact error message you get. (click here)
ssue:
ERROR LCD: INCORRECT PAPERSIZE
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Here are instructions for changing the setting of the tx report:
Issue: How do I change the TX report
Solution: Changing the TX Report-IC D/PC 1000 Series
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif > to select [FAX SETTINGS], then press <Set>.
  3. Use <la.gif > or <ra.gif > to select [REPORT SETTINGS], then press <Set> twice.
  4. Use <la.gif > or <ra.gif > to select the option you want.
Name Description TX REPORT 111OUTPUT NO
111PRINT ERROR ONLY
111REPORT WITH TX IMAGE
111111ON
111111OFF
111OUTPUT YES
Enables/disables automatic printing of a transmission report. No report is printed.
Prints a report only when a transmission error occurs.
If you select PRINT ERROR ONLY or OUTPUT YES, enables/disables printing of the first page of the fax under the report.
Prints a first page only when a transmission error occurs.
The first page is not printed.
Prints a report every time you send a document.
(The factory default setting is in bold face.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 20, 2009 | Canon imageCLASS D880 All-In-One Laser...
Canon i320
Try unticking ENABLE BIDIRECTIONAL SUPPORT on the Ports Tab under Printer Properties accessed through control panel / Printers and Faxes. Try to print - get error message Enable Bidirectional Support. Reverse back into Ports Tab and re-enable Bidirectional Support and try printing again.
Jan 13, 2008 | Canon BubbleJet i320 Printer
Dell V313w AllInOne InkJet Printer Logo
255 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Richard C Cohen
Richard C Cohen
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
