Question about Samsung Computers & Internet
Hello I have a samsung sync master 732n monitor. The power button just blinks but the monitor doesn't turn on it's properly plugged in to my computer. This has happened quit a few times already. When I push the menu button a small screen shows saying "test good," along with 5 small circles that look like bullseyes please advise Thank you
    Sergeant:
  • 358 Answers
Hi your monitor is working ok but your pc display is the problem.
1.-take out the Memory and clean with eraser the gold part of the memory and your problem will be finish .
if still same means maybe your video card or board .
if your board have a video card build in take your video card and use only built in video
last press the keyboard Num Lock and look if ther is a light green
Posted on Nov 03, 2010
6ya staff
SOURCE:
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
Samsung sync master 2033 samsung sync master 2033
Bypass Samsung Lock Screen Pattern, Password, Pin and Fingerprint Without Data Loss
Android Unlock is your ideal choice to unlock Samsung without password in minutes,no more series steps,no more security problems.This helpful program is used to solve Android locked screen problems effectively.Now the latest version currently supports Samsung devices only.
It can help Samsung users disable the password and pattern lock issues on Samsung device without data loss,afer remove the phone's locked screen,you can access your contacts, SMS, pictures, emails or other important data.The program applicable Samsung device including Samsung Galaxy S9/S8/S7/S6/S5/S4/S3,Note 5/4/3,etc.
LEARN MORE
Jun 18, 2014 | Samsung SyncMaster P2250 22 inch LCD...
How to check Samsung 732N 17 inch Monitor Power supply module
Open the case, open the main power supply board out and check the dc volts on the pins of the connector to the VGA board the volts are written in the board
Nov 28, 2011 | Samsung 732N 17" Monitor
Hello. I have a samsung sync. T200 for about 2.5 years.few days ago when i booted my pc the monitor did not switch on. I rebooted the pc and it switched on. I was doing this for 2 days.today has not...
Either your PC video card has fried or it is in fact the monitor that is malfunctioning. Try plugging another monitor into the PC to test which is the problem. If the test monitor still doesn't display your desktop then it is indeed a problem with your system and not the monitor. In this case you will need to have a techinition assess the damaged components. If you can faintly see your desktop in the background then it may be a backlighting issue with your monitor. See my tip here: http://www.fixya.com/support/r6836567-lcd_monitor_displays_background_fine
Apr 17, 2011 | Samsung SyncMaster T200 LCD Monitor
When i start my computer up my samsung 732n monitor comes on, for i see the initial boot info but then it goes black. even tho the blue light button is on.. i have to press the power button, onthe monitor,...
i think this not from yor monitor, but from your PC, is your PC ok???not infected by virus??try uses another monitor, if there still like that it means your pc infected by virus, reinstall your pc
Dec 05, 2010 | Samsung 732N 17" Monitor
My samsung syncmaster 732NW moniter doesn't gives the display. the ligth in the power button at right bottom corner only blinks, please help me!!
First place to look will be the power supply section, see if it has bad caps (bulging top), check to see if you have 12~18vdc feeding the inverter circuits, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | Samsung 732N 17" Monitor
Motor power
you need your power supply repaired. buzzing sound is a bad disc capacitor. blank picture can be bad mofsetts, invertor and bad capacitors.
Dec 27, 2009 | Samsung 732N 17" Monitor
I cant unlock osd of my samsung monitor , sync master 551v
Please try again to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. regards
May 27, 2009 | Samsung SyncMaster 151 N 15" LCD Monitor
Computers & Internet Logo
207 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
