Is very simple. Under the console or display, are some small cover , Press the small tab and you will 2 spring where is located the batteries.
Put some contacts cleaner for electronic, before to assemblies the batteries.
Blessing. [email protected]
cell+whatsAPP:+50588611441
SOmetimes belts make noise when they are worn out and need to be replaced - belts like that are considered 'wear' items, like tires on a car - they have a very limited lifespan compared to the other parts.
Precor has standardized their error code messages across all their equipment so that each error will have the same meaning regardless of what model or equipment type the message appears
Here we list each error so that you can click through the specific error for additional details about the cause and action to correct the error
Precor Error 45, Lift Moving in Wrong Direction
Probable Cause
1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action
1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
