SOURCE: should the spark plugs spark when you on off ther kill switch
WELL A COUPLE THINGS IT IS INDUCTIVE IGNITION TCI YES SPARKS DO AND ARE SUPPOSE TO SPARK ONCE WHEN POWERING THE SYSTEM ON NORMAL BUT IF NO POWER ON ACCELERATION YOU MIGHT HAVE A IGNITOR PROBLEM OR WRONG SPARK PLUGS CHECK TO MAKE SURE WIRES ARE GOOD THE FUEL IS FLOWIG PROPELY AND THAT COIL WIRES SARE GOOD THE SAFTY SWITCHES THEN ALL GOOD YUO HAVE BAD TCI?BLACK BOX
SOURCE: 1979 honda cbx 6 cylinder, no power at 1 coil. no
If you mean no output power, coil is bad. If you mean no input power 12v, there is a fault in the wiring. If you mean no signal from stator, wiring problem as well
SOURCE: cluch dieagram for a honda cbx 750
Go to( babbitts.com )you can get the picture with the part numbers.
SOURCE: I am currently rebuilding a 1983 honda cbx 550
It could be a number of things, and the first two solution both could be right. If it is a problem as outlined by neddz, and you live in Australia, try running the bike and putting Fuel Doctor in with your fuel. My CBX 550 regularly gums up as I need to add a lead additive to the fuel. To counteract the gumming, I put in Fuel Doctor with every tank and it works a treat. You will have to shock treat your first tank with almost half the bottle, but it will definately clean your jets and carbs. You can buy it at Supercheap Auto.
