That means the WiFi radio has a problem with low power. If you have any other devices connected wirlessly and they work OK the WiFi radio in your laptop is faulty.
Typically that is located in the software of your router. Which means you need to open a web browser on a connected computer. Usually the URL to access the router's configuration page is: http://192.168.1.1 default username: admin password by default: admin
in the configuration from there under wireless, and then wireless security, there would the location of the WPA key be.
For wireless connection you need a wireless adaptor in your laptop. Most of the laptop comes with wireless adaptor. If you have one then go to control panel--> network connection--> right click on wireless connection and view available networks in your area.
Please note : If you see a lock sign in front of a network it means that network is secured and you cant access it without password.
Please mail me if you need any other help or if something is not clear in my answer
Please rate my answer and Good luck !!
There are many possibilities - we'd need many more details.
What operating system (XP, Vista, Mac, Linux)? Can you find the router with the computer? Can you connect to the router at its address (usually 192.168.<something>)? Make and model of the router? Any error messages?
The 1st question I have is, are you using the official Microsoft wireless adapter (sold seperatly) manufactured by Microsoft? That is the first solution to this issue. If so you must go into your router settings using the home router IP address usually listed on the router unit and setup the router manually to see the microsoft wireless adapter (sold seperatly), try typing this ip address into your browser address line (192.168.1.1) this is usually a generic router IP address to access your router. Your 360 should have a MAC address listed when in the settings and that should be seen by the router as well. Also check your firewall settings to make sure that it allows wireless transmissions. ( My computer usually has to be running for it to see wired & wireless devices properly). I also prefer just running a wired network for connectivity issues with wireless, such as other electronic interferrence from cordless phones & microwaves as I sometimes get with my nintendo Wii. PAeasop
Best results would be to install everything from a HARD wire connection. Wireless, can drop bits of data depending on interference. I would definately use the ethernet to install everything and then try the wireless.
