Sounds like it is not proving flame, to check you need a meter that will read DC microamps. without knowing the brand I can't say what you should be looking for. Trane furnaces need at least 1 DC microamp to prove presence of flame. Usually you will see 2 - 2.6 or so, but it depends on what the manufacturer specs to prove flame. At minimum you can pull the burners out and clean them really good (especially the cross-over wings) because if the flame doesn't roll down to the sensor fast enough during the trial for ignition it will recycle and eventually lockout. If it stays lit longer than 20 sec, it most likely is proving flame and cycling off on high limit because the blower is not coming on. The typical blower on delay is 45 sec from the time flame is proved to when the blower is energized
