Question about Microsoft Xbox 360 Console
My xbox isnt shwoing picture but sound only what do i do
Posted by pelion222 on
Anonymous
    New Friend:
  • 27 Answers
Http://sharecash.org/download.php?file=1406844
http://sharecash.org/download.php?file=1406556
Posted on Nov 02, 2010
I can hear my xbox 360 but the picture isnt showing up on the tv
check that your color cables are secure in the tv... Possibly your audio is in securely but you need to tighten the picture one.
May 14, 2010 | Microsoft Xbox 360 Console
Why is there no picture on my xbox only sound
hi, you can try unplugging the lead from your telly and also from your xbox then with your xbox switched off at mains plug them back in make sure you push it into the telly far enough as this could be your problem also make sure its fitted in xbox properly the problem is usually the telly end so make sure this is fitted correctly, then switch it on and see if it is now working, if it isnt then the chances are your going to need a new lead, if the problem was with the xbox then you would have no sound as well so the problem points towards the lead being at fault.
Also make sure the telly is on the correct channel
Mar 26, 2010 | Microsoft Xbox 360 Console
My xbox 360 isnt working, i can hear the sound but no picture on screen. Im pretty sure that i have plugged yhe tv input right in
Don't worry , you did everthing right.
What's wrong is pin 428 under the G.P.U
has unsoldered itself and killed the video.
There are many D.I.Y. fixes for this problem.
It's called a standerd X clamp mod ( on the G.P.U.
only). this will get your picture back.
hard to say for how long ,2-9 months.
Or you can have a repair shop re-flow the
G.P.U. for around 80.00 .that fix will last longer.
Rob
Oct 22, 2009 | Microsoft Xbox 360 Console
The picture doesnt show but I hear the sound.
Don't worry the HD feed from the xbox 360 has a gain limiter
So the chances are more likely that either your Friends xbox has
the HD setting off or the TV has defaulted to standard video in.
If you get a black screen or a mesage that says no single .
But if your getting strange color on your set with the HD on
then we need to investigate this " Microsoft is liable!" for
damages caused by their console. Ill look in to this and
follow up. The xbox has broken connection under the poorly
soldered G.P.U. and will need to be re-flowed to the main
board to corrects this problem but that's a secondary priority
right now.
I'll check this out for you and follow up.
Rob
Oct 03, 2009 | Microsoft Xbox 360 Console
Xbox picture wont come up on tv
Firstly (i know it might sound silly) but is your video cable set to composite or HDTV? If that isnt the problem, your video encoder chip at the back probably has cracked or stressed solder joints that will need resoldering at the correct temperature with a special heat station.
Give us a call if you need help doing it.
FixMyConsole
May 20, 2009 | Microsoft Xbox 360 Elite Console
Tv repair
If it works with regular cable or antenna TV then it is probably a bad video cable on the Xbox 360. If it does it all the time then I would replace the TV.
Dec 12, 2008 | Microsoft Xbox 360 Console
No picture
it could be that u r not hoooking it
Jul 28, 2008 | Microsoft Xbox 360 Console
I have sound but there isnt a picture???
Change the Av Cable to hdtv or regular tv based on your unit
May 09, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
