Question about Microsoft Xbox 360 Console
Every time i buy a brand new game i put it in and says this disc is unreadable
Posted by subarugavin on
Anonymous
    New Friend:
  • 27 Answers
You must patch the game for wave 2. Download wavepatcher, patch the game (iso file), write it with imgburn to DVD+R DL
download wavepatcher here: http://sharecash.org/download.php?file=1407192
Posted on Nov 02, 2010
I bought a new xbox360. the game that came with it works great. I also bought the guitar hero. when i put in my new disc and it says unreadable. Replaced with a new disc still says unreadable. Other game...
If the guitar hero is new, I recommend taking it to where you purchased it and having it replaced. Tell them it will not play on your brand new XBox. Sometimes, rarely, you can get a defective disc.
Hopefully that will fix your problem. If not, you might look into returning the system for a new one.
Jul 25, 2011 | Rockstar Games Video Game Consoles & Games
My son was playing his brand new game that we just opened modern warfare 2. while playing the game a message popped up disk is unreadable. we cleaned it with a cloth and now everytime we put the disk in...
Thoroughly check the disc for scratches (especially around the center of the disc, those usually are the most important). If you don't see this message in his other games, it may be the disc. Perhaps try returning the disc and buy a new copy. If he gets the same message, contact Microsoft for further support.
Jun 29, 2010 | Microsoft Xbox 360 Console
All discs results in error " disc is unreadable "
360s are known for laser problems and heat problems on the motherboard, I would replace the laser first,if that fails....buy a new 360,the motherboards are almost the same price as a new unit that has a warranty.
Jul 07, 2009 | Microsoft Xbox 360 Console
It will read some disks but not all disks and the ones it readds i try to play latter and it dont read
i had this problem with my xbox and its due to either the laser or the magnet within the disc drive that holds the disc in place. the magnet may have come loose which mean u can either open the drive up to try and reposition it, or replace the drive all together. my suggestion would be to send the xbox to microsoft if under warranty or send it to a third party company to see if they can fix it. buying a new drive for your xbox involves some very complex firmware flashing which is not advised
Jun 02, 2009 | Microsoft Xbox 360 Console
Random unreadable disc errors
I had the same problem but i sent it in. They said it was the eye reader error. Or the thing that reads the disc. Try buying a brand new game and try playing it. Alot of times when i have disc read errors i put the disc in where the xbox 360 part at the top goes in facing the xbox. Try that to see if it helps.
Mar 15, 2009 | Microsoft Xbox 360 Console
360 scratching discs
use PLEDGE spray can on it to fix the scratches
Jan 27, 2009 | Microsoft Xbox 360 Console
A single unreadable xbox disc, all the others work
the only thing i can think of is taking the disc back and exchanging it for another gears of war 2 disc and try that if that one does the same thing then it appears the xbox doesn't like it thats all i can suggest :)
Jan 05, 2009 | Microsoft Xbox 360 Console
Disc Unreadable
Your laser lens is going out and needs replacement. Either replace the whole drive (but switch out your old circuit board into the new drive) or buy a new laser and install it in (model number is etched into the bottom of the laser).
You have to switch your old board out of the old drive into the new due to Microsoft having "Keys" locked into each drive so you cant fix your system easily. So remember to keep the boards seperate and switch the old board into the new drive and install the new drice... should fix it nicely.
Nov 08, 2008 | Microsoft Xbox 360 Console
Madden 08 is unreadable with my hard drive connected
Hmm.... I encountered this once. Check the disc and check for scratches. Then, use a dry soft cloth (must not be wet at all) and rub it around the disc but don't rub the center of the disc. If this doesn't work swap the game. I mean give the Madden with the problem to EB Games or Gamestop and swap it for a brand new one. It should work fine.
Jan 02, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
