If you want to examine the matrix you want to inverse and, the one that is given you trouble pressing [2nd] [MATRX]. Then stroll and, select the one you want to look at by pressing, [ENTER]. You'll have to press, [ENTER] again and, matrix should display at the Home screen. At the Home when you get to them your looking for the ones that are not square, like 2 by2 or 4 by 4 etc. You might need to re-edit this matrix so, that it is square.
Your trying to invert a matrix that isn't square you might be using using the proper key sequence to create a inverse matrix. Here what the correct inverse matrix look on the Ti 84 Plus Home screen.
And pictured below is a Matrix is being inverted by using the ^ and the -1 keys. Which to inverse a Matrix on the Ti 84 Plus you have to use the [x^-1] key.
This is not the proper way to inverse a Matrix on the Ti 84 Plus. The proper way to inverse of a matrix, the [x-1] key must be used, instead of pressing the sequence [^][-][1]. The [x-1] key is the official inverse key and is located right under the Math key. It is also the same key that you use to get to the matrix menus. The [^][-][1] sequence is only raising the matrix to the -1 power and, will cause an error too. If you need any more help, just post a comment and, I'll respond quickly.
