Question about JVC AV-32120 32" TV
ONIDA 200D 20'' CTV NO PICTURE SOUND OK ,CIRCUIT USED M57228SP
Posted by sujitkarmaka on
3 Related Answers
gopakumarg43
  • 76637 Answers
SOURCE: onida 21''ctv picture coming in stamp type
Hello
Replace its Horizontal output Transistor. If the base-emitter junction has a leak inside it, this type of fault will occur. Before replacing it, check the main DC voltage to LOT [Line Output Transformer]. It should come around 102VDC. If there is not this much voltage, check the electrolytic filter capacitor connected across thie supply line to main negative for open or value developed. Replace the same is good. Till there is low voltage found, check the retifier diode that rectifies this 102 volt DC. If all the above are OK and still you get a stamp like raster, check the heat of the Horizontal Output Transistor described above. if it overheats, LOT is defective and should be replaced with same type and number. OK.
Posted on Jun 12, 2011
Shailesh Parikh
  • 83 Answers
SOURCE: Onida Audioport 21'' CTV no picture & sound
this is video section problum .pls check video mute trangester is sort.
or croma ic is filed
Posted on Oct 20, 2009
mohan orion
  • 49 Answers
SOURCE: sir,
MOST OF THE 2499 TR IS DUPLICATE .SO YOU USE ONLY OLD TR.WHICVH IS TAKEN FROM OLD CTV BOARD. OTHERWISE YOU CAN USE 25INCH CTV H OUTPUT TR.
Posted on Aug 03, 2010
WHAT IS THE NUMBER OF EHT OF ONIDA CTV USING IC R2J10171GA-89FP
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Onida CTV using str f6654 excess volt why?
Check all the related components at the power regulator circuit; after de-solder out the STR from circuit. If all are found OK, the STR is faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the phrase " My service table today " in the search box of the display window [at the top right]. You'll get related posts gathered for reference.
Onida ctv no sound pictur is ok
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
My onida ctv no sond pictur is ok
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
1helpful
Onida igo 20 '' ctv t v 110 voltage one second
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Check the horizontal output transistor for collector to emitter leak.
Onida tv circuit diagram
Check its speaker first. If found OK, check and replace damaged component/s at its audio output section circuit, and check for any loose solder terminals at the audio output IC.
Gopakumar Gopalan Google
My 20"onida ctv candy model set on but 5to7minnet after sound ok but vertically picture jumping or fillaraking please help me technically
Vertical rolling is the fault. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
2answers
I am having Samsung CTV set DNleJr 21
Check its speaker and audio output circuit.
2answers
Sir, my onida 20xs ctv make high boost transister 2499 has burnt
1helpful
JVC AV-32120 32" TV Logo
Top JVC Televison & Video Experts
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
