E197 Error Codes caused by electrical noise.
DETAILS:
The error code E197-0000 (laser scanner motor communication error) may be indicated during the wait state upon power-on. Cause: The tube protecting the crimp terminal on the end of the bias cable that is connected to the transfer guide in the rear side of the Registration - Transfer Assembly [1] moves downward, and the uncovered metal portion of the terminal comes into contact with the screw [2]. This causes electrical noise, leading to E197-0000.
Canon error E197 0000 is a printer engine communication error.
check for firm connections on the DC controller PCB and image processor PCB. If fails to help try replacing the two printed circuit boards mentioned above in that order.
good luck ..
the error is E197-000 Printer engine communication error
Erroneous communication between the DC controller PCB and image processor PCB was detected.
- Check the connectors of the DC controller PCB and image
processor PCB.
- Replace the DC controller PCB for normal connection.
- Replace the image processor PCB.
The part number for the DC controller PCB is FM2-8365-000.
E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation error E019 0001 Waste toner full detection 0002 Waster toner full detection sensor failure E052 0000 Duplex unit connection error E100 0000 BD cycle out of range E196 0001 Error on writing and readout ROM of image processor PCB (main ROM). 0002 Error on writing and readout ROM of image processor PCB (option ROM). E197 0000 Erroneous communication with printer engine E261 0000 Zero-cross signal error E500 0001 Finisher communication error E520 0000 Offset error E531 0000 Stapling error E540 0001 Paper surface not detected (standard tray) 0002 Not moved within the specified time (standard tray) 0003 Sensor not reached within 3 seconds (standard tray) 0005 Encoder clock failure (standard tray) E542 0001 Paper surface not detected (optional tray) 0002 Not moved within the specified time (optional tray) 0003 Sensor not reached within 3 seconds (optional tray) 0005 Encoder clock failure (optional tray) E575 0000 Stack delivery error E584 0000 Shutter failure E716 0000 Erroneous communication with optional cassette E719 0000 Erroneous communication with card reader (serial communication) 0002 Erroneous communication with coin vender (serial communication) E730 0000 Inside error of the image processor PCB (PDL system error) E733 0000 Erroneous communication between controller and printer E736 0000 CCU communication error E739 0000 Erroneous communication between controller and network board E744 0001 Language file/boot ROM/USB memory error 0002 0003 0004 E805 0000 Fan failure E808 0000 Fixing drive circuit failure
- Check the connectors of the DC controller PCB and image processor PCB. - Replace the DC controller PCB for normal connection. - Replace the image processor PCB.
I have a Canon MF6500 Series and received this System Error E197 error while printing a document from Word. I was low on paper in the tray but not out so I refilled the paper tray and turned the printer off for about 30 seconds and it worked fine after that. I guess I'm lucky.
I believe a E197 error refers to a power problem relating to the fuser. I would remove any covers to access the fuser, remove it and reseat it and any nearby connectors.
