Canon PIXMA iP5000 InkJet Photo Printer Logo
Posted on Nov 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace ink waste absorber - Canon PIXMA iP5000 InkJet Photo Printer
Anonymous
Level 3:
  • Master 475 Answers
  • Posted on Nov 02, 2010
Anonymous
Master
Level 3:
Answers
475
Questions
Helped
129061
Points
1535
  • Open the printer as though you were going to install new ink cartridges, letting the cartridge cradle move to the center of the printing unit. Unplug the printer so that the cartridges will remain in their position.
  • Locate the waste ink absorbers in their black rubber frame. They will likely be on the right side of your printer, and will be located underneath the area where the ink cartridges rest when the printer is in standby mode.
  • Use a paper napkin or other disposable and absorbent material to soak up any excess ink that may be in the pads by pressing it down onto the top of the frame.
  • Pull the rubber frame free from the printer, wearing gloves to keep your hands clean. Carefully remove the ink absorber pad or pads from the rubber frame.
  • Insert new ink absorber pads firmly into the rubber frame. Replace the rubber frame in its original position and close the printer.
  • Hold down the power button, then plug the printer back in. Continue holding the power button down until the printer begins to reset itself and come online.
  • Wait for the green power light to turn off, then press and release the power button again. It should blink for two to three seconds, then stay lit; this will indicate that the printer has been reset and is ready to print again without errors.
  • 5 Related Answers
    A
    Anonymous
    • Posted on Mar 23, 2008
    SOURCE: how to reset waste ink absorber full ip3300 warning?
    I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
    Anonymous
    • Posted on Aug 05, 2008
    SOURCE: Canon iP2000 Waste Ink Absorber - where is it for washing and replacing?
    the waste ink absorber, but I can't find where it is to wash and replace - thanks!
    Anonymous
    • 118 Answers
    • Posted on Mar 04, 2009
    SOURCE: waste ink absorber
    Try to reset it. Use software reset tool, you can download it here free
    Anonymous
    • 6 Answers
    • Posted on May 31, 2009
    SOURCE: I have a Waste Ink Absorber problem that will prevent printing
    Try this to reset the error.
    1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
    2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
    3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
    4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
    5) Press the Power button. The LED lights in green, and the
    selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
    6) Power off then back on and test.
    Anonymous
    • 28 Answers
    • Posted on Sep 04, 2009
    SOURCE: waste ink absorber is full,
    hi,
    CANON PIXMA MP160 All-In-One InkJet Printer
    has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
    http://www.canon.com/printer/prob676ijt65/solution
    prirweto-i-5
    1helpful
    How to reset the full ink absorber
    You do not want to reset the waste ink absorber. The machine monitors the waste absorbers, and they are full. If you continue to use it, it will leak waste ink. Take it in for absorber replacement, or replace the unit.
    1helpful
    "ink absorber is almost full, contact service center" - what does this mean?
    Inkjet printer has waste ink absorber inside, sponge alike. The function of waste ink absorber is to localize and keep waste ink safe inside the printer and does not harm the electrical parts.
    Waste ink is produced from print head cleaning process and borderless printing. When capacity of the ink absorber raise to about 90% then warning message appears.
    You need to bring your printer to the nearest service center to get waste ink absorber replaced.
    Source:
    Printer Clinic: Printer Tips,tricks,troubleshooting
    E-manualshop: Online source of service manual
    Screen shows picture of printer cartridge holder and message "waste ink absorber is almost full"
    It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
    The WASTE INK ABSORBER KIT is approx. USD10/pcs
    Ink waste absorber almost full where do I get a new one?
    You may request from www.comcentre.com.my
    Waste ink error message, now the printer won't print until the waste ink tank is emptied or replaced.
    1helpful
    Full ink absorber
    2helpful
    2answers
    Message" waste ink absorber"
    There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
    Check your user's manual about the procedure for changing the absorber and where to buy new ones.
    5helpful
    How do I clean the waste ink absorber on a cannon ip90
    We are not advice to clean WASTE INK ABSORBER.
    7helpful
    2answers
    Ink absorber full
    This is a very common problems with canon printers. They are set for a certain number of prints and they need the ink absorber serviced. Now along with resetting the printer its best to replace the absorber. Here is link to site that has reset instructions.
    http://ij-forum.blogspot.com/2008/08/reset-waste-ink-absorber-error-waste.html
    Thanks,
    Lee
    4helpful
    Printer says ''waste Ink absorber is full'' see service center
    This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
    Canon recommends to contact a Canon service representative as soon as possible.
    old marine
    old marine
    ZJ Limited
    ZJ Limited
