Nokia E63 Cell Phone Logo
Posted on Nov 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have installed untrusted nokia e63 theme after installation its hanging anyhow i switched to other mode pls suggest me how to remove the hanging one theme withour factory setting
Anonymous
Level 2:
  • Expert 251 Answers
  • Posted on Nov 02, 2010
Anonymous
Expert
Level 2:
Answers
251
Questions
0
Helped
44228
Points
988
THE ONLY SOLUTION FOR THAT IS TO RESTORE YOUR PHONE INTO FACTORY SETTING. you can also save your files and contacts to your PC via nokia pc suite (the latest one) and start resetting your phone. thats the only possible way to restore your phone deleting the hanging theme.
1helpful
2answers
My nokia e63 mobile i can't install themes that replys is application error contact ur application supplier thats it my mble problem plz send a my request
This is not your mobile problem. It is theme problem which you are trying to install. Theme may certificate error. Try to install another theme. Or set time to your mobile if you have invalid time on your mobile. Hope your problem fixed.
I installed lots of theme in my Nokia E63 after installing one of the theme, the screen went blank white, and I can only see the battery meter and signal meter. The rest is blank white. I restarted it,...
The phone has hung up because there are some errors in the installed software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
http://www.blogsdna.com/2278/how-to-format-nokia-n72-n73-n81-n95-nseries-mobile-phones.htm
4helpful
I am not able to change theme in nokia e63. actually i installed a new theme yesterday and applied it. but after that e63 is not supporting so many operatins. i just want to change the theme now,...
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
I installed a theme which was not compatible with my nokia e63 and now i can't remove it form the phone.. please tell me how i can solve my problem. i jus got the phone like a week ago..
I think the theme that you have just downloaded carries a virus and brought it to your phone since it is also not compatible with your handset model. Where did you store the theme? if you saved it in your memory card, copy all the other files that you have there and save it first to your computer. Once you are done doing it, go to My Computer, locate your memory card, click the right-click and then choose format so that your memory card will be cleared. After clearing the memory card, you may transfer all your other files to your memory card, except for the incompatible theme..
I suggest you these sites.. :) enjoy downloading themes and other stuffs much compatible to your handset model! ^_^
http://www.ownskin.com/theme/Nokia/E63/344/1/
http://www.mobileheart.com/cell-phone-themes/1604-Nokia-E63-Themes.aspx
http://gallery.mobile9.com/c/nokia-e63-themes_1997/1/
1helpful
How to install E63 themes?
There are three ways that you can install your Nokia themes on your phone. One is through over the air downloads, in which case, you just go directly to the site with your chosen theme, click on the link, and follow the instructions on your phone.
If you're downloading the themes on your PC, there are two ways you can install it on your mobile phone. One is through the Nokia PC suite, and the other is through Bluetooth or data cable transfer. follow these instructions
Using Nokia PC Suite:
1. Connect your phone to your PC and turn on the Nokia PC Suite or wait for the application to start.
2. Click on the "Install Applications"
3. When a window appears, browse to where you have saved the downloaded themes using the left part of the window.
4. Select your chosen theme and then press the arrow in the middle of the window
5. Follow the instructions on your phone screen and you're done.
Bluetooth or Data transfer (only for N-series and newer phone versions)
1. Data transfer. Connect your phone via USB cable and select "data transfer" on the mode menu. When you connect your phone and it shows up as a removable disk, transfer the theme on your phone's storage card. You can install the theme by using the file manager and selecting the theme to install. 2. Bluetooth. If your friend has a theme on their phone, you can have them transfer it on your phone via Bluetooth transfer. The theme will appear on your messages and to install it, simply click on the transferred file on your messages and follow the prompts.
hope this helps...
30helpful
4answers
2helpful
I have a nokia e63 original.. but i can't install themes what should i do?
To install themes.
- Just copy the themes on your memory card.
- Note the date of copying and put that particular date in calender settings. And enjoy the themes.
2helpful
E63 hangs!! i open apps and nothing happens
1. you need to reboot your phone by pressing no. 3 + * + Power button simultaneously and the phone will be back to its original factory setting (fresh) - hard reset
MAKE SURE YOU BACK UP ALL CONTACTS, MESSAGES and OTHER DATA
2. It seems that you have installed a couple of "untrusted" third party application such as Iphone themes, games,etc
I happen to have the same phone with the same problem and now its okey.. hope it helps :)
19helpful
5answers
Problem in install application
If you own Nokia E-series mobile phone (E60, E61, E70),
you may want to do following in order to allow phone
to install SmartMovie:
1) Open Application Manager
2) Choose Options, then Settings
3) Switch Software installation to *All* (not Certified only)
This will allow you to install non-certified applications.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
