Question about Toro Lawnmower 20099 Mower Mowers Lawn
My toro lawn mower is hard to start in cold weather. (40 to 50 degrees), I have an auto-choke. mower was bought in spring of 2010.
Posted by judyaj1251 on
  • Anonymous Nov 02, 2010
    No solution, only a little advice. Toro warranties this mower as "Guaranteed To Start" for 2 full years from date of purchase. Go to www.toro.com to find your nearest servicing dealer. Let the dealer figure it out. It might be something simple, like needing a lighter weight oil.
  • Anonymous Mar 27, 2014
    My lawn mower sat all winter and now it will not start
Joseph Mueller
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
This is covered by the Warranty. Take it to a local dealer like www.arcolawn.com and have the thermostat replaced.
The first generation thermostats are known for sticking.
Good luck
Joe
Posted on Feb 20, 2011
Where is primer on craftsman platinum push mower
It may not have one. Some mowers auto choke using spring tension on the choke plate in the carb. They open the choke when the engine speeds up after starting.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 23, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Toro choke doesn't work
try cleaning out the carburator.
May 23, 2017 | Toro Lawn Mower With Toro Power Tools
I have a Toro 20" self propelled, electric start
I am strictly Briggs&Stratton. They are hard to start when the fuel tank is half empty. Clean the plug and air filter.
Jun 15, 2011 | Toro Power Lawn Mower
Hard to start n cold wheather put new battery in it still having trouble
I suspect the choke isn't closing fully. Remove air cleaner down to where you can see the choke butterfly. With the controls in choke position that butterfly should be completely closed. If not you can adjust it. If this is cable operated, adjust it by loosening the screw that holds it on the bracket and slide it until choke closes. This is done usually on carb end. I am also assuming it runs fine after start. Hope this helps.
Dec 08, 2010 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
New honda hrr auto choke hard to start
sounds like it may need the carb clening out, but it could be the auto choke not closing when cold. there was an issue with some of the early auto chokes on the gcv135/160 engines so check to see if the choke flap is in the closed position when starting from cold, run the engine for approx 10-15 minutes and see if the choke flap has opened fully.leave it to go cold and see if the choke flap has returned to the closed position
Apr 12, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Mower won't start. Toro mower..engine won't turn over. Cleaned sparkplug...checked air filter..weather cool. Followed instructions for cold engine...prime witrh three pushes of the bulb..wnon't even hint...
Something everyone over looks is oil. Did you check the oil? You seemed to mention everything else but. If you have a low oil switch with low oil it will not start
Nov 28, 2009 | Toro Lawn Mower With Toro Power Tools
Toro lawn mower wont start
pour alittle gas in carburator & then try starting see what happen if it starts & then dies then you have a carburator problem
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
Toro riding lawn mower. 12 h/p is hard to start
Hi there, It is most likely that the choke isn't closing fully. The throttle cable will need to be adjusted to cure this. The cable is clamped where it joins the engine. Simply slacken the bolt and move the outer cable out a bit. When you operate the throttle control you should see the choke start to operate near the start position. Make sure that the choke control rod operates to its fullest extent when the control is fully on the start position.
Sep 08, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawnmower 20099 Mower Mowers Lawn Logo
1,039 people viewed this question
Top Toro Garden Experts
Dennis Key
Dennis Key
Marvin
Marvin
dannydoesita
Are you a Toro Garden Expert? Answer questions, earn points and help others
