HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
Posted on Nov 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the printer carriage access door located?
Anonymous
Level 2:
Novelist:
  • Expert 119 Answers
  • Posted on Nov 01, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
119
Questions
0
Helped
39442
Points
364
Hi
The door shown in this picture is carriage access door
Where is the printer carriage access door located? - 2386b83.gif Let us know if in case you need any more information
All the best!!
Regards
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 24, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
811
Points
Printer message" Open the print carriage door and clear the jam". After doing this , the message keeps on coming back and I can't print. Help needed please
Thanks
We have a ESP 7250 the print head carriage shows jammed but I can't get the ink cases to move. So I can check it
To resolve this error: Open the printer access door. Disconnect the power adapter from the printer. Gently hold both sides of the carriage, located immediately behind the printhead, and make sure the carriage moves freely. Remove the printhead and ink cartridges. Reinstall the printhead and ink cartridges, making sure each clicks into place. Connect the power adapter to the printer. Turn the printer on. Close the printer access door Hope this helps resolve your problem
1helpful
Carriage jam
Hi
The carriage door is the cartridges access door.Access the cartridges and make sure they're properly installed.To open:
  • Turn the machine on.
  • Open the cartridges door by lifting from the front center of the device until the door locks into place on its own.
Printer error code 3820
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Gently hold both sides of the carriage, located immediately behind the printhead, and make sure the carriage moves freely.
  4. If the carriage does not move freely, contact us.
  5. Remove the printhead and ink cartridges.
  6. Reinstall the printhead and ink cartridges, making sure each clicks into place.
  7. Connect the power adapter to the printer.
  8. Turn the printer on, if necessary.
  9. Close the printer access door.
aFor more help visit cbrtechsolutions
I have a Brother HL 1440 that had the paper jam in the front and back, crumbling up in the process. I cleared both locations with no success. The ready and alarm continues to flash and the printer still...
Check the following steps for fixing Brother Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
2helpful
Paper jam press ok to fix-then I get error code 3820
  4. Remove the printhead and ink cartridges.
  5. Reinstall the printhead and ink cartridges, making sure each clicks into place.
  6. Connect the power adapter to the printer.
  7. Turn the printer on, if necessary.
  8. Close the printer access door.
If the error continues, contact Kodak.
I am getting the following error message: "0x07d54dd6 2005: lib_barracu". How do I fix it?
Can you turn the machine on and lift the print-carriage access door, this should (hopefully bring the cartridges to the right side where you can remove them) If this is possible, remove the cartridges and then turn the unit off, if the cartridges stay in the same location where you can access them then place the cartridges back into slots and turn the printer back on.
If the cartridges are not accessable then turn the printer on and open the print-carriage door, and insert cartridges.
Please let me know! Thanks!
regards Abhilash
What does error code 3820 mean for a kodak esp5 all-in-one printer
The error message "Carriage Home detection failed" (error code 3820) can be resolved by following these steps:
1.Open the printer access door.
2.Disconnect the power adapter from the printer.
3.Gently hold both sides of the carriage, located immediately behind the print-head, and make sure the carriage moves freely.
•If the carriage does not move freely, contact Kodak.
4.Remove the print-head and ink cartridges.
5.Reinstall the print-head and ink cartridges, making sure each clicks into place.
6.Connect the power adapter to the printer.
7.Turn the printer on, if necessary.
8.Close the printer access door.
2helpful
3answers
My officejet 5610 says "carriage jam. Open Door etc. I can't find a door to the carriage.
Hi!
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on.. open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper from the roller...return the paper output tray and the carriage access door. plug the power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriage access door.
disconnect the power cord from the back..remove the paper output tray...look inside if the carriage is stuck and if there is no papers or object that restrict the carriage to move..return the output tray.. return the carriage access door...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on the printer..disconnect the power cord from the product..disconnect the power cord from the wall outlet.. wait for 15 seconds.. plug the power cord to the wall socket....plug the power cord at the back of the printer.. press the power on of the printer.. try to print the test page...
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
2answers
What is a carriage jam
3. Clear the paper jam from the front of the printer..while printer is on..open the carriage access door..
look inside the product..check for torn papers..gently pull out the paper fromthe roller...return the paper output tray and the carriage access door. plugthe power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriageaccess door.
disconnect the power cord from the back..remove the paper output tray...lookinside if the carriage is stuck and if there is no papers or object that restrictthe carriage to move..return the output tray.. return the carriage accessdoor...
To reset the printer....press the power button to turn on theprinter..disconnect the power cord from the product..disconnect the power cordfrom the wall outlet.. wait for 15 seconds.. plug the power cord to the wallsocket....plug the power cord at the back of the printer.. press the power onof the printer.. try to print the test page...
http://www.fixya.com/support/t6088190-hp_7400_displayshttp://www.fixya.com/support/t6088190-hp_7400_displays
1helpful
Error message reads "carriage jam"
The print carriage access door is the large top part of the printer that swings up. If you look in the user guide it is arrowed on page 14.
If you don't have a copy you can download it here:
http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Hope this helps
k24674
Grand Canyon Tech
Grand Canyon Tech
