Question about Insignia D300a PC Desktop
Well i dont know the model number or name of this decice but its a two piece audio set,its fairly new i got it within a range of 5-7 years and its showing a question mark next to multi media audio device and the speakers are insignia. all i need is the speakers working because sound wont come out.
Posted by leoscarano on
5 Related Answers
Anonymous
  • 934 Answers
SOURCE: Manufacturing coeds for Insignia
Go here: http://service.us.panasonic.com/operman/Default.aspx select remote control guide, find the model of your remote and get all the available codes for that remote on all the devices it supports. Site also lists owner's manuals in pdf for download..
Bill
Posted on Dec 02, 2007
Anonymous
  • 13 Answers
SOURCE: audio card
Do you mean the sound driver for the D300, or did you buy a separate sound card? How is it you don't have sound but you have everything else? The recovery disk for D300 should have the software drivers, that or go to intel's website.
http://downloadcenter.intel.com/Filter_Results.aspx?strTypes=all&ProductID=1065&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
Scroll down and download the Audio Realtek software driver.
Cheers,
Posted on May 14, 2008
Anonymous
SOURCE: Insignia NS-A2111 audio issue
I had the same problem, its an easy fix if you can solder, and costs less than five dollars in parts, The two filter caps in the audio power supply are not soldered very well so vibrations cause them to break loose from the board.
Posted on Feb 08, 2009
Anonymous
SOURCE: insignia digital tv converter/indoor antenna no signal
I had the same problem but realized that when it said NO SIGNAL,,,,it just ment for that station,,,,,switch channels and they will start to come in,,,
Good Luck,
charh20
Posted on Feb 22, 2009
marionbagget
  • 718 Answers
SOURCE: Insignia TV suddenly no sound
Go into the SOUND section of the menu. Find the TV Speaker out option and make sure its on.
Make sure the VOLUME is not set to zero !!
Posted on Feb 23, 2009
I will like to know what year is this bicycle j.c higgins searial # MOD50245460
Google "J.C. HIggins serial number", but you may not have luck. The exact year is not important, as the style of bike will be fairly consistent in a range of years, as will value. If it's a 3 speed check the rear hub, which will have the month and year of manufacture on it. The bike model will be within about a year of that. I can tell you that bike was manufactured by Murray of Ohio, due to MO serial number.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Oct 09, 2017 | Cycling
Finding out what model name or number motherboard i have
The Asus model will always be printed in fairly large letters on the face of the motherboard near the bottom. It's kind of hard to read at first, so hold it out in front of you at arms length.
May 13, 2009 | Computers & Internet
Dont know my model number?
HELLO
You will find the model number on the back of the TV. It's usually a square white sticker with all the info of the set (chassis type, model number, power rating etc).
When you have all the info, go on the web and do a search and I'm fairly certain you'll find a replacement. A generic type will do all the functions of your original - unless you want an original one of course! But I would advise against cheap code type remotes that will not do everything. (:-)
Feb 20, 2009 | Bush 5693D 24" TV
Ge profile spacemaker over range microwave not heating
It was probably the Magnatron tube that went out , they are normally replaced only under warr. due to the cost to repair , the part is roughly 200.00 and labor ranges from 100-200. I guess it all depends on what it is worth to you , you can pick a decent brand new one up for about 200. Hope that helped you out. Phil
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire Model FEFL78CSA oven not heating
I apologize for not getting back to you sooner. I tried to respond to your question yesterday, but the web link was not working. Your assumptions are probably correct as the ERC controls all the oven features on an electric range. This is a fairly simple repair job that any do-it-yourselfer can accomplish.
The ERC is easily accessed by removing the back panel of the operator console. The circuit board is screwed in place with a series of wire connectors. Most models have the wire color coding printed on the circuit board for ease of identification. In addition, there should be a wiring diagram located either inside the console, or on the back of the range. This will also list the color codes. If not, I would recommend you label all wiring BEFORE removing to ensure everything is reconnected correctly (a digital camera can come in handy as well).
New ERCs generally do not come with the overlay. This is the plastic printed face-piece that covers the front of the board with all your controls and numbers. Some manufacturers provide this with the new ERC, but MOST do not. The existing one can be reused by carefully removing and reinstalling to the new ERC. You may consider ordering an overlay too if yours is in bad shape.
You can order a replacement at searspartsdirect.com. Pcappliancerepair.com also carries the part for just a few cents cheaper. I recommend the sears website for the helpful exploded view illustrations. Just type in your model number and look under the "Backguard" heading for item number 20 (part #316207529). The overlay is listed as item 20A (part #316220804). If you wish to save a little and order from the other website, use the part numbers provided by Sears for your search criteria as I could not find your model number listed.
Please ensure you UNPLUG the appliance before servicing. No special tools are required. If you have questions, please post back and let me know. I hope this helps you.
Nov 27, 2008 | Ovens
I dont know which drivers to be installed for audio .
Hi deepakbandi,
the model number you have listed is not 100% correct. If you found another site that shows two audio drivers, please list the link here in this post.
Or goto this VIA link & match the model number to the motherboard picture.
http://support.octek.com.au/Products/MainBoards/P4/VIA/mb_p4_v_08.htm
As you will see, P4M-266 is part of the model number. 8233 is part of the chipset.
VT8233 chipset. P4M266A-A4E Pentium 4 Main Board. There are two On Board Audio AC97 Drivers.
Download & install 2 channel audio (VT8233): http://support.octek.com.au/Update/VIA/V823x.htm
Mike
Oct 27, 2008 | Computers & Internet
Electrolux dishlex dishwasher
www.nzherald.co.nz said it affects Electrolux dishlex machines with serial numbers 70700000 to 72400000
Jul 25, 2008 | Electrolux 23 in. ESL624 Built-in...
THE STYAINLESS STEEL COOKTOP
I NEED TO REPLACE MY STAINLESS STEEL 5 BURNER WITH GRIDDLE COOKTOP ON MY 36 I TAPPAN RANNGE BUT DONT KNOW WHERE TO FIND ONE. I CANT SEEM TO FIND THE SRIAL NUMBER/MODEL NUMBER ON THE STOVE. HELP! DAN WILLIAMS
Jun 16, 2008 | Tappan MGF500PBW Gas Kitchen Range
Oven fire
wrong call [email protected] 100-851-6200 and they will help you have the model number handy before you call
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Insignia D300a PC Desktop Logo
Top Insignia Computers & Internet Experts
Michael Thomas
Michael Thomas
Kevin Nelson
Jax Planet
Jax Planet
Are you an Insignia Computer and Internet Expert? Answer questions, earn points and help others
